Thread: dxf to pcb
    Can anyone turn a dxf into a pcb file, ie gerber or similar?
    Ian
    if you download the trial version of cnc-usb, you can import as a dxf & then save as a gerber....
    http://www.planet-cnc.com/files/CNCUSB_20130308.zip
    or was that not what you meant?
    pcb2gcode perhaps??
    Thanks for the replies. Cant find the export option for cncusb and it wants to router the holes rather than drill then but that could be the dxf.
    Pcb2gcode wont output a gerber file.
    I do have a copy of Diptrace which will do the job but I cant figure out the layers at the moment. I was hoping to get this one done quickly so I will probably send it to one of the board manufacturers tomorrow if they can take dxfs.
    Regards
    Ian
    My apologies, it's the other way around....it imports gerbers & outputs dxf [I'll get me coat]
    Seems that designing PCB's in AutoCad is not the accepted convention?? DXF/DWG to Gerber Conversion Guidelines | Numerical Innovations
    Maybe this can do what you want if you save your DXF as a PDF first: http://swannman.github.io/pdf2gerb
    Or this? http://ask.metafilter.com/143118/how...CB-fabrication
