Page 2 of 2 FirstFirst 12
    Lives in East Lothian, United Kingdom. Last Activity: 3 Hours Ago Has been a member for 9-10 years. Has a total post count of 2,039. Received thanks 225 times, giving thanks to others 5 times.
    wobblyjelly
    OK, here's my dilemma: absolute maximum distance from motor shaft centre to Z dovetail is 90mm. It looks a bit touch and go whether or not a 90 frame motor will fit. According to THIS thread, which is an almost identical machine, they used a 1.1kW 2-pole motor with an 80 frame size and report that it only *just* fits. As said by Jonathan earlier in this thread, a 4-pole motor will give better torque but will have to be run up to 100hz to get the desired speed of around 2800RPM. But I can't find a 1.1kW 4-pole motor with a frame size less than 90...
    So, assuming I use an 80 frame size, would I be better off using a 2-pole 1.1kW OR downsizing to a 0.75kW 4-pole? Or can anyone provide a link to a 1.1kW 4-pole in an 80 frame size?
    Just spoke to my motor supplier.
    You can get 4 pole in 80 frame at 1.1Kw, if you move to 2 Pole you can go up to 1.5kw
    They don't have them but about 3 days lead time.
    You need to talk to Martin at M&R Controls 01773 875795
    John S -
    Thank you John. The 2 pole 1.5kW might be a nice solution as it means 2800RPM without running the motor at twice its rated frequency.
    As a man with experience of these machines, what would you normally choose?
  5. #15
    Hi there birchy, I am planing to do the same thing to my WM16 (fed up with changing brushes) but am thinking about keeping the 2 speed gearbox but replacing them with steel gears to give me a degree of backgear. The primary drive will be by toothed belt I think. Have you come across ant major problems with your conversion?
    Regards Mark P.
  6. #16
    If you have money to burn you can go the AC servo route and get 1.65Kw in a 85mm square flange motor and you will have more power than you will need on that small machine.
    http://www.kollmorgen.com/en-gb/prod...-servo-motors/
    Graham
  1. FOR SALE: (G0704 SPG 2217 Champion 20V Mill Warco WM 16) DC motor
    By fragger6662000 in forum Items For Sale
    Last Post: 09-10-2011, 04:59 PM
  2. Warco WM16 Conversion
    Last Post: 25-03-2011, 08:32 PM
  3. Warco mini mill cnc conversion
    By buster in forum Milling Machines, Builds & Conversions
    Last Post: 20-03-2011, 06:48 PM
  4. CONVERSION: Warco VMC Turret Mill - CNC Conversion
    By antsals in forum Conversion Build Logs
    Last Post: 06-03-2011, 11:25 PM
  5. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 03:26 PM
