Thread: EPS Block
    Anybody know where I can get a piece of expanded polystyrene foam 400mm x 200mm x 100->200mm ? In Nottingham would be ideal, otherwise cheaply by post.
    Rob
    You can normally find this kind of thing around B&Q in the insulation section, if there is a broken sheet ask if you can have it for a discount :D
    Have you tried the local builders yards? Sure they must get full sheets that get broken & might sell you a bit.
  1. RFQ: Billet block
    By youngblood in forum Projects, Jobs & Requests
    Last Post: 02-04-2013, 09:17 PM
  2. Understanding the bearing block
    By Rogue in forum Rails, Guideways & Bearings
    Last Post: 28-08-2011, 03:14 PM
  3. NEW MEMBER: new designer on the block
    By lugtigheid in forum New Member Introductions
    Last Post: 29-12-2010, 08:56 PM
  4. RFQ: Rising block for Tom Senior M1
    By rnr107 in forum Projects, Jobs & Requests
    Last Post: 24-12-2010, 07:06 PM
  5. NEW MEMBER: New Kid on the block
    By 25ncjimmy in forum New Member Introductions
    Last Post: 24-07-2009, 06:01 PM
