Page 2 of 2 FirstFirst 12
    Many thanks Jazz. Here are the 2 TAP files.
    tracks
    drills
    And here are my settings.
    Note that after some advice on here I changed Step Pulse to 5us.
    The settings above are somewhat different to what my machne setup guide suggested, which was 400 steps, 2000 velocity, 200 accel, 10 step and 3 dir. The machine did not move to the correct scale with these settings.
    Ok well you don't look over tuned. 1800mm/min velocity isn't overly fast but it could be at the upper limit of tight or worn machine, esp these low power machines with crappy electrics. For a test you could drop velocity to 1000mm/min.
    Personally don't think this is the problem has the code use's very few G0 rapid moves, plus most are Z axis moves and the G1 commanded moves are all low feed moves.
    The G-code is fine and everything lines up. I've Attached combined files. Combined_Tracks_Plus_Drills.txt.zip
    First for simplicity's sake I would check the mechanics of the machine.
    Check for loose couplers or signs of slippage.
    Check ballscrews for end float and ballnuts for backlash.
    Check all axis for binding screws or linear bearings things like this can easily rob steps from a low power machine.
    One problem I've encountered with these machines is very poor quality wires and connectors, esp the stepper wires. Infact the whole electrics are shit.!!
    Go over the wires and connections with fine tooth comb. To be honest For the price of few meters of shielded cable it's worth replacing the stepper cables anyway. Electrical noise could be affecting the motors and shielded cable grounded at the controller end only will help reduce this.
    If the electrics check out ok and there's no binding etc in the mechanics then can't suggest anything else other than trying on a different PC in case you have parallel port issue.?
    After this if your happy with the machine and it's mechanics(so long has it use's ballscrews not lead screw) then I'd throw away the crappy all-in-one drive boards and put some decent motors with 50v drives on it along with 45V PSU.
    This will sort any electrics problems and make the machine fly.
    Good luck.!
    This turned out to be connected to the y axis stalling issue. The machine was loosing steps because the clock speed was set too too high.
  1. Tool diameter accuracy
    By Neale in forum Tool & Tooling Technology
    Last Post: 05-03-2014, 10:18 PM
  2. Replies: 25
    Last Post: 01-10-2013, 04:17 PM
  3. Machine bed accuracy
    By Colin Barron in forum Gantry/Router Machines & Building
    Last Post: 03-11-2010, 10:24 AM
  4. Cheapo Leadscrew with minimum accuracy requirement!
    By Vikash in forum Lead Screws, Nuts & Supports
    Last Post: 06-10-2010, 10:17 AM
  5. Ball Screw Accuracy V Price
    By Wobblybootie in forum Lead Screws, Nuts & Supports
    Last Post: 02-01-2010, 10:55 AM
