Thread: Brass Signage
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 31-03-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Hello all.
    Had a recent commission to make a one-off brass sign with a rather large area that needed gloss black resin... I did the metalwork on the new(ish) gantry router that Clive and I built last summer (with his help I'll be upgrading it to two screws on the long axis in the not too distant). There was a bit of resonance, but nothing that caused any problems. I'm happy to go slow to keep those cutting forces low...
    I used 0000 Grade steel wool to de-burr and 'relax' the sharp machined edges before polishing and cleaning it a few times over.
ID:	25187 Click image for larger version.
ID:	25188 Click image for larger version.
    My DIY resin approach is fine for smaller scale stuff, but for this rather large job I took the resin work out of house to a company in Hockley, Birmingham - Capricorn Coating Services - the results are superb. A few pics:
ID:	25190 Click image for larger version.
ID:	25191 Click image for larger version.
    Before commencing work I drilled and tapped four shallow M6 holes to the rear of the plate - these will accept 60mm studs that will get epoxied into four holes drilled in the wall. Overkill..? Probably..
    Wal.
    Lovely job Wal!
    Though we expect nothing less of you ;-)
    - Nick
  3. The Following User Says Thank You to magicniner For This Useful Post:
  1. Right bit for cutting brass
    By centurian in forum General Discussion
    Last Post: 14-07-2018, 04:40 PM
  2. Replies: 0
    Last Post: 27-06-2017, 11:49 PM
  3. Drill bit for brass
    By CNCDev in forum Metalwork Discussion
    Last Post: 23-09-2016, 06:44 PM
  4. Cutting Brass
    By KennyL in forum Milling Machines, Builds & Conversions
    Last Post: 20-12-2014, 06:31 PM
  5. RFQ: I need apx 100 brass tubes being cut down
    By Chance1234 in forum Projects, Jobs & Requests
    Last Post: 02-04-2014, 02:05 PM
