    therefore maybe something like these at the right speed...
    Dremel Brad Point Drill Bit Set - 631 | eBay (they go up to 1/4")
    never used them for tin, but they work great on acrylic! (& handy to have in your arsenal of bits - especially if your machine is confined/restricted to a 1/8" collet, such as a rotary tool in this arrangment - https://www.google.co.uk/shopping/pr...g&ved=0CCAQrRI)
    I want to avoid drilling if I can , I want a sort of high bred clamp come punch template combo , ill work on it and see what I can do, thanks for the replies guys :)
    Ralph Waldo Emerson
    Lives in East Lothian, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    juliuscaesar
    Hi Fivetide
    regarding die press, a decent pillar drill should provide enough pressure for punching thin stuff,clamp your die to the table (simples)
  5. #15
    What about this sort of punch press?
    eBay item no.
    121130794607
  6. #16
    Whitney punch
    Ebay 221245161892
    peter
  7. #17
    You'd probably get a decent hole if they were drilled with a milling slot drill. Probably a nice job for a CNC. Unless you fancy building a CNC punching machine...
  8. #18
    Rotabroach annular cutter (aka mag drill cutter) often does a good job on sheet too... but you'd probably need a mill to hold the shank (fits nicely in a 19 mm ER32 collet). Sizes go down to 12 mm in standard series, never tried the 'mini' ones.
    ah just seen it's a 1/4 inch hole so as you were...
  9. #19
    All great ideas but I have to be quite accurate with the holes, after marking them out then drilling chances are they won’t be that accurate. The PCB has about 5 mounted parts that need to go through the holes on different sides and there’s no play. Plus they have to be neat. So that’s why Im thinking of making a template I can slip over the edge of the tin box, sort of an inverted U shape and then using a hardened bolt that’s been cut down with a cutting edge done on a lathe that then screws through the die and punches out the holes.
    Ralph Waldo Emerson
  10. #20
    A bit like these:-
    Q.max Sheet Metal Hole Punch 25mm
    But I don't think they are made down to 5mm. ...Clive
  11. The Following User Says Thank You to Clive S For This Useful Post:
  1. The new probe and finding the center of a hole
    By Ricardoco in forum Probing, Digitizing & Scaning
    Last Post: 13-11-2015, 06:43 AM
  2. Hole Radius
    By benkat in forum Machine Discussion
    Last Post: 03-03-2014, 05:29 PM
  3. SBR16UU Centre hole.
    By cambesol in forum Rails, Guideways & Bearings
    Last Post: 25-11-2013, 05:39 PM
  4. 6mm shaft to 6.35mm hole?
    By JuKu in forum Metalwork Discussion
    Last Post: 15-12-2012, 02:29 PM
