Page 2 of 2 FirstFirst 12
    Lives in East Lothian, United Kingdom. Last Activity: 7 Hours Ago Has been a member for 9-10 years. Has a total post count of 2,061. Received thanks 228 times, giving thanks to others 5 times.
    thisonecouldofbeenleftuneditted
    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 1 Day Ago Has been a member for 6-7 years. Has a total post count of 251. Received thanks 1 times, giving thanks to others 11 times.
    Thank you gents, this is exactly why I've asked the question, I've never thought about it to be honest.
    Regards,
    dsc.
    dsc's Avatar
    One more question regarding the fitting of the 'barrel' of the ballnut inside the housing. Normally the non-flange part of the ballnut is marked as 'g6' tolerance and if I'm not mistaken it's a slide fit in the housing. Any reason for this other than space saving and making the bore in the housing an almost exact fit? I'm asking because the mounting holes on the flange are 4.5mm dia, which means there's some wiggle room to align the ballnut with the ballscrew, but of course in order for that to be possible, the bore for the body of the ballnut needs to be slightly bigger than g6.
    Regards,
    dsc.
  1. Plasma floating head...
    Last Post: 01-01-2015, 12:52 PM
  2. advice on floating bearing - outer ting rotating
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 18-11-2013, 01:23 PM
  3. non-locating / floating bearing - shaft location
    By dsc in forum Linear & Rotary Motion
    Last Post: 28-06-2013, 09:07 PM
  4. Driving floating end (ballscrew)
    By blackburn mark in forum Lead Screws, Nuts & Supports
    Last Post: 11-09-2010, 10:55 AM
  5. Looking for a housing for your electronics?
    By Smiler in forum Electronic Project Building
    Last Post: 01-09-2008, 06:38 PM
