Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by Fivetide View Post
    Plus I think they use a plasma cutter on the plate as the edges look melted and nasty.
    No not at all I've had hundreds of feet of plate from them and never has it been cut with plasma, always looks like band saw teeth marks to me.!! . . . . If you have had any like this then think it must have been a one off, i'd have sent it back in your case.
  2. #22
    Mine were cut with a circular saw. They sunk the blade about 5mm, started the cut then noticed it was too short and adjusted. That went back to them. Nice clean sharp cuts though.
  1. angular contact bearings - back to back, further apart
    By dsc in forum Linear & Rotary Motion
    Last Post: 05-01-2014, 09:59 PM
  2. wobble / wiggle on ballscrew double row angular contact bearing
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 14-12-2013, 07:35 PM
  3. Aluminium passivation - for aluminium to be used outside
    By CHudson in forum Metal Finishing Techniques
    Last Post: 06-04-2011, 08:18 PM
  4. Ballscrew machining details
    By HiltonSteve in forum Lead Screws, Nuts & Supports
    Last Post: 24-07-2009, 03:01 PM
  5. NEW MEMBER: First contact
    By subtractive in forum New Member Introductions
    Last Post: 26-04-2009, 08:03 AM
