    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 4 Hours Ago Has been a member for 6-7 years. Has a total post count of 366. Received thanks 41 times, giving thanks to others 14 times.
    Hello,
    Anyone interested in making me 3 ballnut brackets for my RM1605 ballnuts?
    I'm using TBR20 rails with the corresponding blocks, and the spec of the bracket I need is a bit different to what I've seen available to buy.
    Please find attached a couple of .jpgs which illustrate the specs I'm after, and also a .zip file which unzips to the following:
    RM05 Ballnut Bracket for use with TBR20 BF_BK:
    • RM05 Ballnut Bracket for use with TBR20 BF_BK PROFILE.pdf
    • RM05 Ballnut Bracket for use with TBR20 BF_BK.dxf
    • RM05 Ballnut Bracket for use with TBR20 BF_BK.pdf
    • RM05 Ballnut Bracket for use with TBR20 BF_BK.stl
    NB - the "RM05 Ballnut Bracket for use with TBR20 BF_BK PROFILE.pdf" has holes that are 4.2mm (for tapping M5)
ID:	9339Click image for larger version.
Name:	RM05 Ballnut Bracket for use with TBR20 BF_BK.jpg
ID:	9340RM05 Ballnut Bracket for use with TBR20 BF_BK.zip
    Drop me a PM if you can help - or indeed, if you know somewhere that sells what I'm after..!
    Wal.
    Wal's Avatar
    Or maybe a simpler profile cut from 20mm plate if the 40mm depth is putting you off... Like this:
ID:	9344 Click image for larger version.
    RM1605_ballnut-bracket-20mm.stl
    RM1605_ballnut-bracket-20mm.dxf
    (I'll make up a proper drawing if there are any takers...)
    Cheers!
    Just realised I forgot to reply to your message about this. I can make them to either design, but not for 2-3 weeks. How soon do you need them?
    Wal's Avatar
    Hi Jonathan,
    I'm not in a mad hurry for them. Of course, I'm keen to have 'em in my hands as then I can get the next stage under way, but if I have to wait a couple of weeks then that's cool.
    I'd prefer the design in the OP - for it's sturdiness. There's a good chance that I'll be needing a spindle mount too.
    PM me a price and let me know about any extra info that you may require.
    Cheers.
    Wal.
  1. WANTED: Ballnut Bracket needed please
    By EddyCurrent in forum Items Wanted
    Last Post: 24-02-2014, 10:15 AM
  2. WANTED: FOUND: RM1605 ballscrew, at least 365mm (ish)
    By Jonathan in forum Items Wanted
    Last Post: 08-09-2013, 01:01 AM
  3. RFQ: Bracket parts from Nylon
    By egimson in forum Projects, Jobs & Requests
    Last Post: 17-04-2012, 11:20 PM
  4. RFQ: Aluminium bracket help please.
    By Kevin G in forum Projects, Jobs & Requests
    Last Post: 03-11-2011, 01:43 AM
  5. Replies: 7
    Last Post: 27-09-2011, 11:04 PM
