    Hi to all, first post so go easy on me ok.
    I have a Chinese router 2500x1300x200. I know, probably a mistake but ..............
    The Y axis (2500) is driven by 2 steppers with their own MA860H drives. The step and direction inputs are connected in parallel so should track each other. However if one of the motors should miss a few steps due to high cutting forces at one end of the X stroke, or maybe one end of the gantry being knocked whilst the machine is off surely the x axis will be pushed out of square with the Y axis. With me so far? Any ideas how can I prevent this from happening? How is it done on "professional" machines?
    Thanks for any thoughts,
    Bob.
    Hi Bob,
    One of the ways to solve this that I know of is to run the motors independently (separate control signals) from mach3, i presume your machine uses that software? you can then set up your y axis to use motor 1 (Y axis) and motor 2 (A axis). Then when you reference your machine at startup you have 2 microswitches (one for each end of the gantry), the machine travels towards these, touches, then offsets and if you have your microswitches set true to your machine you will have a square gantry. Unfortunately I don't know how you can overcome the motors loosing steps, unless you use encoders to create a closed loop system, similar to how servo's work.
    Adam.
    Thanks Adam, I had thought along those lines. The machine currently has NcStudio with a PCI control card. This only has the 3 outputs so driving the second motor with a fourth is not an option. I may just have to bite the bullet and go for a Mach 3 system.
    This is common corner cutting with Chinese machines, chances are the 2 motors share just one drive has well.? Bad bad idea just asking for error and trouble.!!
    First of all Mach3 doesn't support closed loop so fitting encoders won't help here. Mach will read encoders and show encoder position in a DRO but can't act or do anything other than that.
    I have a couple of suggestions.!! All include dumping NCstudio and using Mach3 using the parallel port or if you want better stability and higher speeds using motion control card like Ethernet smooth stepper.
    First getting round the racking or should say minimising the chances of it happening and preventing damage if it does.
    The most common cause of missed or lost steps and then subsequent racking with twin motors is over tuning the motors and pushing them far to close to the corner speed where torque drops away.
    Often what happens is the motors don't stall but they don't have enough torque to hold position when deaccellerating or accelerating hard so get pushed along thru inertia effectively losing position by step here or there. This then accumulates over the course of the job to such a point the racking affect stalls the gantry.
    The easy solution and really the only way to be sure racking doesn't happen with twin motors is to de-tune the motors and run them well below the motors corner speed. The problem then comes from lower speeds for cutting or rapids.!!
    The solution to this is to use higher pitch screws and gear them so the motors can run at lower speed where torque is higher and still give reasonable speed and resolution.!! . . . . . All easy enough if your building from scratch but not so easy if your stuck with existing screws.!!
    So the next best thing is to use Good digital drives that have Stall detection built into them like leadshine AM882, these drives have a fault output signal which can then be tied into the control E-stop system and stop the machine when it sees stall happening. They won't show missed steps or correct for missed steps but they will detect when motor is stalling and protect the machine from doing damage thru racking. They are also very good drives for resonance and just very nice drive in general.
    The next option is to use the Hybrid servo stepper system which is actually closed loop stepper system but closed by the drive not the Control so will work fine with mach3 or any control that doesn't have closed loop capability's.
    This system will not run out of position and will correct for positional error if it does. It works very much like a servo system but use's stepper motors with encoders meaning it keeps the cost down.
    The drives can be setup with fault tolerance values so if the positional error becomes too great, say thru inertia pushing gantry etc, then outputs a fault command which can again be incorparated into the E-stop system bring the whole machine to safe stop.
    Now they are expensive compared to standard steppers/drives but cheaper than Servo's. . . .Now often folks think Servo's are better than steppers but this actually isn't the case for machines that don't require high speeds or carry heavyloads.
    Steppers if run correctly can be just has accurate and reliable, plus much much simpler to setup and keep running compared to servos.
    Also with control software like Mach3 that don't support closed loop they don't actually offer any advantage over steppers has they won't correct for positional error.? They will report positional error and servo drives can be setup to fault if exceeds programmable settings but other than that they offer no advantage. . . . .This is where the hybrid servo stepper wins because it closes the loop internally and corrects for positional error has well has faulting if greater than set parameters.. . Win win.
    They are also Digital drives so very good regards resonance handling and very simple to setup with none of the tuning issues servo drives can come with.
    Some where on this forum and utube I posted video showing testing hybrid system, check it out.
    Hope this helps.!!
    PS: . . .Oh the other way to completely eliminate racking is to connect screws with timing belts and use Single large motor like I do on my machine. In over six years I've not dropped one step(thru sensible tuning) or lost position ever (except thru my own error) and the gantry is perfectly square because screws are always kept perfectly in sync so gantry just can't rack. I've run jobs that lasted 30+ hours without stopping and when finished sent home and be perfectly back where it started.!!
    Thanks for a very detailed reply, my machine uses rack and pinion drives to the x and y axes so mechanically linking them would be somewhat cumbersome. I did think of a single larger motor with drive shaft passing through the gantry to drive both ends but that's a lot of work. I think I'm going to look at dual datum sensors and tuning the motors for a more reliable operation. Currently the motors drive the racks via 20 tooth mod 1.5 helical spur gears through 1:5 reduction so they are not turning at particularly high speeds. Quick question though, what exactly is the "motor corner speed"?
    Thanks again,
    Bob.
    Quote Originally Posted by cncbobuk View Post
    Briefly It's the point in the motors speed curve where torque drops off quickly leading to stalling soon after.
    That's brilliant, thanks.
    This system will not run out of position and will correct for positional error if it does. It works very much like a servo system but use's stepper motors with encoders meaning it keeps the cost down. ...
    I have a plugin for my machine that came with it. Its for the close loop that can be added to the motors. It works in Mach3. I mean if some body needs it just drop me a PM and i will send it to you. But hushhhh !Basically you need additional inputs on the BOB and enter the correct values for the encoders in Mach3 setup.
    Nope I doubt it.? . . .It's probably just reading the encoders and displaying coordinates MACH3 CANNOT do true closed loop to my knowledge.
    That said I'm intrigued to the Plug-in so please email me it. . . Think you have my email.
  1. Preventing rust on machine tools
    By gavztheouch in forum Machine Discussion
    Last Post: 05-06-2014, 01:27 PM
