    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,551. Received thanks 166 times, giving thanks to others 654 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    As it says on the "Tin":
    .Me
    Just be careful, that equation assumes the LED requires 20 milli Amps of current, the proper equation is (Vsupply - Vled) = IR, or R = (Vsupply - Vled) / I in this case. V is in Volts, I is in Amps, and R in Ohms.
    20 mA = 0.020 Amps.
    Some minature LEDs go pop on less than 20mA :)
    Technically speaking LEDs require a certain current, not a certain voltage, so it is possible to run a LED from a higher voltage supply without a current limiting resistor, as long as the supply is switched so that the average current is at or below the LEDs forward current.
    The more I learn about this hobby, the brighter the light of knowledge grows, the deeper is the pit of ignorance revealed...
    I'm using this online calculator - you will also get the power requirements for the resistor - it calculates the Wattage of the resistor - depending of the voltage of the circuit
    http://led.linear1.org/1led.wiz
  4. The Following User Says Thank You to karul For This Useful Post:
  1. cnc machine stiffness calculator
    By routercnc in forum Linear & Rotary Motion
    Last Post: 03-05-2015, 10:55 AM
  2. Simple O-ring calculator.
    By jcb121 in forum General Computing
    Last Post: 26-07-2013, 08:00 PM
  3. Resistor Question
    By GTJim in forum General Electronics
    Last Post: 07-04-2013, 09:01 AM
  4. ATX power supply - load resistor - do I need one ?
    By rckeith in forum General Electronics
    Last Post: 18-08-2010, 02:21 PM
  5. What type of resistor?
    By Smiler in forum General Electronics
    Last Post: 05-12-2008, 09:04 PM
