Thread: Proximity sensor help required
Nope, the resistor has nothing to do with what Mach3 displays.
21-08-2013 #2
This is normal if using the PLCM motion controller with mach 3.
It is because if you hit the limit the controller goes into estop condition and stops talking to mach 3.
Once you hit the reset switch it will start talking to mach 3 again.
You may need to jog off the limit though, so you should press "auto limits override" button before reset.Visit Us: www.automationshop.co.uk
21-08-2013 #3
Thanks Gary for this info, Still not got the servo working will finish all the mechanical work first then will start to send you the screen prints.
Thanks everyone for all your help.
Proximity switch NPN or PNP
By Matt81 in forum General ElectronicsReplies: 9Last Post: 19-04-2014, 11:38 AM -
Spindle position sensor
By GeoffV in forum Motor Drivers & ControllersReplies: 3Last Post: 23-03-2014, 10:00 PM -
How to Wire this Sensor
By manofgresley in forum General ElectronicsReplies: 1Last Post: 26-11-2013, 05:09 PM -
Proximity Switches
By kingcreaky in forum General ElectronicsReplies: 20Last Post: 23-10-2013, 01:30 PM -
Mdx-40 (with zcl-40) Y sensor bar. Help!
By Rastamonk77 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 12-02-2013, 09:44 PM
