28-08-2013 #11
I forgot to respond to you Jazz, apologies (rude when you are trying to help!)
Nope.
The cable came from one of those chinese TB6500 boards that was included in a 3D printer I bough ages ago. I wonder if that one is a bit special??
The AM882 detects stalls - well it has when I have wound them up to fast in pro tune - red light comes on and it stops ( I might have been trying to see how fast they'd go. . . ). Anyway they are all happy in pro tune and when I connected my parallel port directly to the driver so its not that.
Yeah, I thought it might be noise, but it does the same in and out of the case and in different orientations too. so it isn't because it is in close proximity to power leads (I don't think)
I think the signals are ok as I did a direct connect.
You have been great - I appreciate the input.
Mach works on my other machine - which uses a ZPA board and GEKKO drives so I don't think its the install. I downloaded the ZPA5-INT xml file from the Zapp site and used that - as described above, the stepper nearly jumped off the table.
I do have one solution to this. . . . control box out the window. Done.
28-08-2013 #12
That's were your going wrong.?? Bob's are one of the most trouble some components in the control box and buying cheap boards just increases your chances of trouble 10 fold.!! . . . If you think about it they handle all the signals and no matter how clean the signal when it reaches the board if the BOB has cheap nasty components then it will get degraded to some degree. Now send it usable signal but on the weaker side and cheap board can easily scramble it's brains out.!!
The only board I can recommend which you can buy in UK is this one. I've used many without problems, infact I'm installing one at this moment along with AM882 drives.
OPPBLast edited by JAZZCNC; 28-08-2013 at 03:01 PM.
28-08-2013 #13
28-08-2013 #14
No it's a separate board if you want to control spindle speed.
You can use BOB's On board relays to control VFD start/stop signals. To be honest I don't often bother with spindle speed control and just control Start/stop.
I also use the relay built into VFD to control water pump so it's only running when spindle spinning.!
28-08-2013 #15
Cool - I am not to sure I will need spindle control any time soon. I have 2 really nice spindles, one with a vortex tube on it pumping cool air down the centre of the cutter that I want to get running. The machine it came with had a KEB inverter that I need to start understanding . Spindle control won't be relevant until I have that sorted!!!
28-08-2013 #16
FYI, just tried the board on my Gekko setup and it works fine.
I have spotted something that might make a difference though - so I will try it out and update accordingly. . . . .
28-08-2013 #17
bugger. it didn't work. Sod it, I'm going to buy another board.
29-08-2013 #18
01-09-2013 #19
Boom. Ordered a board from DiyCNC - out of stock. In comes Mr. Jazz to the rescue, sends me his spare (or next builds board). Realised it was out of stock thursday, Mr Jazz sends Friday, received on saturday and 90% wired on Sunday.
Board works a treat - I still don't know what was wrong with the ZP5A as it is working fine on my other machine (Gekko 203V) but this has dealt with the problem.
Thanks to all that waded in to help - particularly JAZZCNC you bloody legend.
01-09-2013 #20
Your Welcome, Cheap BOB's are just not worth the stress and hair loss. . Lol . . . Pleased your sorted and working.
PS: Money received thanks.!!
Leadshine website and AM882
By EddyCurrent in forum General ElectronicsReplies: 12Last Post: 24-08-2018, 01:59 AM -
I NeeD HeLp PLease AM882 a good choise
By jpsicilia in forum Motor Drivers & ControllersReplies: 34Last Post: 16-08-2014, 10:27 PM -
Well it looks like I have to bite the bullet (solid works)
By Kai in forum SolidworksReplies: 9Last Post: 03-04-2011, 01:52 AM -
How Rotary Broaching Works
By steve3d in forum Tool & Tooling TechnologyReplies: 0Last Post: 18-01-2011, 03:17 AM -
My CNC WORKS...
By emboss.shop in forum Metalwork Project ShowcaseReplies: 0Last Post: 30-09-2009, 06:04 PM
