Thread: crazy idea
    I had a dream last night, we've all seen the challenges we face building these machine frames and ensuring they are strong enough/ and straight enough etc. then once made we wish we had made them stronger.
    why would you not make a big wooden box, situate it where you wish the machine to stay for the rest of eternity, then fill the box to desired level with wet cement / re-bar
    once dry, remove box and start building off that (ie, mount your rails directly to the concretre block)
    perfectly flat (because of gravity) no resonance no flex. Im sure there is a massive reason why not but thought id ask just to satisfy my mind
    matt
    It would work within reason for low accuracy machines like cutting wood etc but Because concrete takes an age to settle down and will slowly change shape it's not a good idea for higher accuracy machines.
    I built a Granite shaping/cutting/polishing gantry for my mate which ran on 6ft high concrete block walls with 10x8ft bed which was made using concrete floor beams with concrete block in fills then levelled with Epoxy..!!
    If I was building a wood only machine and had the room with no desire to move it then I would probably take this route has it's easy and cheap using concrete blocks and epoxy.!!
    Have a look at Epoxy Granite
    So, not a new idea but a good one :-)
    Quote Originally Posted by FatFreddie View Post
    Life's too short to read that load of tosh.!!!. . .Lol
  1. Website idea.
    By qwertyjon in forum General Discussion
    Last Post: 11-07-2014, 07:49 PM
  2. Here's an idea hacking a Kress 1050 FME
    By m.marino in forum Kress Milling Motors
    Last Post: 16-01-2013, 12:05 AM
  3. Why they don't want to accept my idea?
    By hoezap in forum Tool & Tooling Technology
    Last Post: 14-07-2012, 12:15 AM
  4. business idea?
    By homer93 in forum Marketplace Discussion
    Last Post: 01-06-2012, 11:56 AM
  5. BUILD LOG: Mel's Odd Idea
    By mel_earp in forum DIY Router Build Logs
    Last Post: 19-03-2010, 10:54 AM
