18-09-2013 #21
Yep those are profiled rails.
If you can find 20mm for not much more then go with those has the slightly larger height and bearing size makes things a bit easier.
Thou 15mm will be fine but you'll need to put raiser blocks between back plate and bearing to give clearance between front and rear plate for ballnut. 20mm mean you just machine a shallow channel in plates for clearance.
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
