  1. Thanks, i'm liking the look of this approach & I have basic electronics knowledge with plenty of soldering experience so should be easy enough to get them running - any chance of a pic showing how you've got one attached to your machine?
    What are you using for limits?
    limits switches are for girls!!! the 'limit' is where the ballnut slams into the bearing housing
    no pictures im afraid, however they are very simple... wave something metal infront of it... and it triggers
    Quote Originally Posted by kingcreaky View Post
    . . . .Ah ah obviously not bent a ballscrew yet Matt or ripped the teeth of a timing Belt..
    Crafty Just buy some cheap-ish micro switches for limits and wire in series. Also arrange them so they get triggered by running over the switch and not into it. Same goes for Home/Proximity switches.
    Also If you want to keep wiring and number of switches down then just have 1 limit switch per axis that travels with that Axis and gets tripped by some fixed but adjustable brackets at each end.
  4. Quote Originally Posted by JAZZCNC View Post
    That's pretty much what I did on my last crappy MDF machine...although the micro switches were a smidge too cheap
    They've been retired...i'll be getting some new ones when the time comes.
  5. #15
    I've got six nice inductive sensors, four of these and two of these. I'm not sure if and how I could use the last ones as they have only two connections. Do I need additional circuitry to be able to use them?
  6. #16
    The four you have are Normally Open type, the preferred type for limit switches is Normally Closed.
    Also take note when you mount them, if you notice they use brass, stainless, polypropylene mounts.
    The last two may be normally closed, it does not say, some of these just change a voltage level so that the input decides if it's on or off.
    This manual shows the wiring arrangements but obviously for their own board.
    http://cnc4pc.com/Tech_Docs/C31R1_USER_MANUAL_REV1.pdf
    You could wire the sensors so they operate the coil of a N/C relay then use the relay contacts as inputs to your breakout board but it's a backward as you have introduced more things to go wrong.
    Personally I would replace them all for 3 wire N/C type.
  7. #17
    If I use them only for homing with additional limit micro-switches will I have any issues being PNP?
  8. #18
    PNP is the most common type used so you should have no issues.
    Technical FAQs | Knowledge Base
    yours are 5-10v so you should not require extra resistors as in this discussion but it makes interesting reading
    http://www.mycncuk.com/forums/genera...-required.html
  9. @paulus:
    You can't use the 2-wire ones directly, they need additional circuitry ( see here for more info)
    Here is a diagram showing how to use the 3-wire ones
    Attachment 9915
    @EddyCurrent - not sure I agree PNP are more common...
  10. The Following User Says Thank You to irving2008 For This Useful Post:
  11. #20
    No me either.!!. . . . Must took the thoughts straight from my Mind. .
  1. Proximity limit switch problems
    By davrich in forum General Electronics
    Last Post: 12-03-2018, 01:58 PM
  2. Proximity switch NPN or PNP
    By Matt81 in forum General Electronics
    Last Post: 19-04-2014, 11:38 AM
  3. Proximity Wiring Problem
    By Bruce in forum General Electronics
    Last Post: 13-01-2014, 07:21 PM
  4. Proximity sensor help required
    By plasticsales in forum General Electronics
    Last Post: 21-08-2013, 07:02 PM
  5. Proximity Sensors as Limit Switches ?
    Last Post: 03-10-2009, 07:04 PM
