Thread: Warco Major CNC build log
M8x40 did the trick, gap closed, put an arrow on the pic in case you couldn't see where it was
03-07-2009 #2
03-07-2009 #3
Because if it gets the faintest jiggle it will never close that sweetly again :nope:
Good idea, but then I'd have had to clean off the RTD and I was rather enjoying putting it together :naughty:
If I take it off I promise to Loctite it
Kip, I don't know how it compares to driving the handwheel because I've never tried that. If I had to guess I'd probably plump somewhere between amazing and freakin' miraculous
05-07-2009 #4
Curious.
I wound up the feed rate on that hybrid stepper and it would do 18mm/s but clacked out at 20 mm/s
I disconnected the Y axis to get some spare Amps then switched the hybrid peak current from 1.9A to 4.2A peak.
Wouldn't do 18 mm/s anymore :nope:
Possibilities...
The cable on the Z is altogether too long and it's having problems controlling the current.
The stepper driver can't actually cope when you increase the current.
I imagined it :heehee:
So, any ideas what driver/PSU combination I need to shop for?
However, 18mm/s is a lot better than I had before so I made new plates to fit them on the X and Y. Stuck a fanciful strain relief bracket on the X so I can bolt the flexy trunking to it.
Haighton Major
By BillTodd in forum Milling Machines, Builds & ConversionsReplies: 25Last Post: 14-05-2022, 02:17 PM -
WANTED: Conect Minor or Major CNC Milling Machine Wanted
By stevy123 in forum Items WantedReplies: 0Last Post: 24-08-2011, 10:35 AM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM -
Warco Super Major Mill 3 month old
By grimreaper in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 18-07-2010, 02:50 PM -
NEW MEMBER: Warco super major mill
By ste64 in forum New Member IntroductionsReplies: 5Last Post: 26-05-2010, 04:27 PM
