Collected machine today, looks quite good, but the cast ally "legs" are in fact feet, and the beast has no legs!!! First job will be to make a table/frame for it and then to sort out the electrics. I may use a different controller than the one that came with the machine.I understand that the machine was built using all ISEL components by a company called Unimatics who were I understand one of ISEL's agents at that time, building and selling ISEL machines to schools etc. Looking at ISEL spec sheets, I think that this is basically a stepper version of the flatcom 40.
Anyway I am very pleased with my purchase to date. G.
04-09-2013 #2
Geoffrey,
I have the smaller version of the same machine, working area 300mm x 300mm
Very good machine and highly accurate and repeatable, mine also had no feet so fitted 4 feet I had kicking around off a X3 milling machine.
Can get pics if you are interested?John S -
04-09-2013 #3
Thanks John, my machine actually has cast ally feet with rubber pads and fixing holes fitted, but the advert said it had legs. The table size is 1350x1000, so I guess the working area is about 1100x900. I have the original ISEL controller, but no cables. What controller do you use? Tanks again. G.
04-09-2013 #4
Home made in an old Shuttle PC box, 452 drivers, simple BOB with spindle relay and running Mach 3
John S -
The Following User Says Thank You to John S For This Useful Post:
04-09-2013 #5
Another ISEL friend!
I have recently acquired an old Flatcom 40, Flatcom 20 and GFM4433. I have replaced the ISEL drivers with various alternatives - the 40 has Gekko 203v's, the 20 has AM882's and I will hit the GFM with some Gekko 201's pretty soon.
I have some spare parts kicking around so give me a shout if you need anything - equally, if you have any bits you want to shift give me a shout!
EDIT: FYI, check inside your control box and really have a good look at the stepper drivers. I was very surprised to see in my Flatcom 20 control box that they had in fact used Gekko 201's that had been painted black and incorporated into an ISEL board. I will be using these to re-fit the GFM machine! I guess ISEL were subbing parts of their control systems to Gekko to save developing their own!Last edited by badgerman; 04-09-2013 at 01:44 PM.
"Hacking" and "Modding"
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
Interesting Article "Makers unite - the revolution will be home-made"
By Fivetide in forum General DiscussionReplies: 4Last Post: 28-09-2012, 12:06 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
My apologies to "Andy" for the delay ... internet connection problem
By ali hedi in forum General DiscussionReplies: 1Last Post: 25-12-2010, 06:05 PM
