    I'm guessing two pipes might be easier than one.
    Jazz, thanks for that, I'd read you mentioned this before and obviously Matt's machine works well.
    So before I set off down the L design how about this one ? pipe + 2 bits of channel
    Yes it would work and tube is very stiff. But large tube is expensive and will resonate quite a bit.!! How about something like this.? It will probably be cheaper and stiffer with 2 x 100mm tubes
ID:	10026Click image for larger version.
ID:	10027Click image for larger version.
ID:	10028Click image for larger version.
    Would the two tubes try to rotate about each other ? they would need to be connected somehow, it seems the basic strength of one tube has been lost maybe, but you are right that large tube might be expensive unless of course a scrap yard had something.
    That gantry you've drawn would be pretty lightweight I imagine.
    They are connected with the plate in centre that bearings fasten too and they would obviously be fastened at the ends into gantry sides. This was a quick mock up for you to visualise and obviously you'd strengthen has seemed appropriate.
    To me there's no point wasting time drawing anything if your not working to dimensions you know are available. Those 2 tubes are standard dimensions for off the shelf steel 100 x 3.2mm. Rest like angle and flat plate is again off the shelf.
    I've not done any bending or testing calcs but I'm sure combined strength of 2 tubes will be better than one large tube unless it's wall thickness is much greater.?
  5. #15
    Jazz, sorry didn't see central plate but I have now. Is this a design you have considered before ? how does it rate compared to other designs ?
  6. #16
    No, one tube will be much stronger. Second moment of area (J) is proportional to radius to the power 4. The deflection is inversely proportional to J, so this means that for instance one 200mm tube would deflect around 16 times less than a single 100mm tube. The big advantage with a single tube is it's the strongest shape in torsion, so if using two I'd make them rectangular/square section as the forces are now mainly bending not torsional.
    So you can't really go wrong if you use a big tube. The same principles apply to box section...
    http://www.mycncuk.com/forums/linear...alculator.html
  7. The Following User Says Thank You to Jonathan For This Useful Post:
  8. #17
    OK how about this, if you have a lathe that will swing a couple of inches greater than the pipe you intend to use you could manufacture a faceplate mounted fixture [...]
    Does that make any sense ?
    Makes sense, but I think pouring epoxy on to the surface and allowing it to level itself, like I did here, is much less work! I'll be impressed if you can achieve the same accuracy with shims, as it's hard to compensate for twist in the rails.
  9. #18
    Jonathan, I downloaded that excellent calculator several days ago and it looks like time needs investing to get the best out of it so because I might only have another 10 years to live can you advise on the size of pipe I might need, thanks. (600mm working bed width 2.2kw or 3kw spindle, cutting hardwood but as seems to be the case with others probably light ally too)
  10. #19
    I knocked this together just to show you but yes I've used tube before on a plasma machine.
    So Yes I wouldn't hesitate using it router and it would be easy enough to make and very strong.
    Like Jonathan suggested I'd either machine the rail surfaces or epoxy them. I'm big fan of epoxy levelling and use it all the time has it's easy for large surfaces and plenty accurate enough for DIY machine.
    Weld the plates on, stitch the tubes together then epoxy and you'll have a very stiff gantry with nice flat rail surfaces.
    Again like Jonathan I wouldn't use round rail, mainly because I think they are rubbish and secondly they are rubbish.!! Profiled rails make into much better and stronger machine, accurate.
  11. #20
    I was thinking more in terms of a complete gantry assembly not just the tube and more regards bending not twisting.!
    Not got time or inclination to fully draw both and test but I reckon it would be very close and really either would be plenty good enough for routing hard wood.
    I also naturally think in terms of what's easily available at sensible prices and 100mm tube will be easy got and cheap 200mm + will be hard and expensive to find.!!
  1. Cast aluminium gantry router
    By jrcast in forum Gantry/Router Machines & Building
    Last Post: 17-02-2017, 08:13 PM
  2. RFQ: RQF: Router Gantry plates
    By lateAtNight in forum Projects, Jobs & Requests
    Last Post: 27-12-2012, 04:56 AM
  3. Double gantry idea, What do you guys think?
    By craigrobbo in forum Gantry/Router Machines & Building
    Last Post: 25-12-2012, 10:01 PM
  4. Router spindle idea
    By HiltonSteve in forum Spindles & Drive Motors
    Last Post: 19-01-2010, 08:59 AM
  5. BUILD LOG: Fixed Gantry Router
    By lateAtNight in forum DIY Router Build Logs
    Last Post: 28-05-2009, 11:30 PM
