    You have to see the electron micrograph to believe it. The gear keeps the insects back legs in synch when it jumps. This has to be the perfect gear form if you happen to be working in chitin...
    The First Gear Discovered in Nature - Popular Mechanics
    Fascinating article!
    I've known some womenfolk who I think may have evolved similar gears at the tops of their thighs, but it was evolution gone bad though, as the gears tended to seize quite often, resulting in them being locked together.
  1. 16 tooth pulley HTD5 15mm on a 14mm shaft
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 07-06-2013, 10:51 AM
  2. NEW MEMBER: Hi Folks form Dorset
    By PatK in forum New Member Introductions
    Last Post: 17-09-2011, 08:53 PM
  3. Mod Bus form china
    By cncezee in forum Motor Drivers & Controllers
    Last Post: 06-02-2011, 03:28 PM
  4. My first gear, a deadbeat escapement gear for my clock
    By clockman in forum Woodworking Project Showcase
    Last Post: 30-01-2011, 10:39 PM
  5. NEW MEMBER: Hello form Lithuania!
    By ZRimaZ in forum New Member Introductions
    Last Post: 05-11-2010, 03:47 PM
