Thread: Ready Steady Eddy
14-09-2013 #6
Yes, i get it. I was suggesting a steel box section profile and 2x 30x30 or similar aluminum profiles fixed on one face so you can imitate your first design. Best would be your design made from steel box.
Looking at the design, what i see is that you try to make flat the z but at the same time the whole Z assembly seriously overhangs on the linear bearings. So making it same but from steel, you could fix the rails further in front up to the near end of the steel box, which you could not do with aluminum.
I have redrawn million times this and until now i couldn't find a real way to diminish overhang without placing the ball screw behind the gantry. For a better understanding is better to draw the spindle mount brackets, the spindle itself and the bit. On the 3d warehouse there is 2.2kw spindle with mounts. So you will have better picture what you gain and at what price and compare actual bit position.
-using flat wide rails 15 size on the Z will gain you 15mm versus 20 size square railsLast edited by Boyan Silyavski; 14-09-2013 at 12:19 AM.
traveling steady, turning 1/2 bar down over 10".
By graffian in forum Metalwork DiscussionReplies: 3Last Post: 08-05-2013, 07:59 PM -
NEW MEMBER: Hello all, finally ready to start a build log.
By Iwant1 in forum New Member IntroductionsReplies: 11Last Post: 25-12-2012, 06:03 PM -
eBay: Boxford 125 TCL Mach3 Ready
By rnr107 in forum Items On eBay UKReplies: 1Last Post: 25-07-2012, 07:29 AM -
Anyone have experience of ready made machines
By bogstandard in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 07-04-2010, 07:44 PM -
Windows 7 RTM Confirmed & Ready !
By Lee Roberts in forum Computer SoftwareReplies: 8Last Post: 29-07-2009, 03:33 PM
