Thread: Driver & Driven
	15-09-2013 #1
Hi
I should know the answer to this, and i think i do, i just need reassuring.
I have a 3Nm, Nema 23 motor, i am going to use to power my Z axis on my milling machine, i intend to use a toothed belt & pulleys, my question is this, should the DRIVER pully (ie, attached to motor shaft) be LARGER or SMALLER the the pulley being DRIVEN (ie attached to Z axis Leadscrew)
Regards
Ray
	15-09-2013 #2
Well really that depends on what your after.? If your wanting higher speeds then larger pulley on driver, this will come at the cost of torque.
If have a fast motor and are wanting slower speeds with more torque then smaller on the driver.
I think you'll be looking to increase torque so go small on driver.
	15-09-2013 #3
It all depends what gear ratios you want to achieve. Generally speaking, a direct drive system would use either Oldham Couplings or drive pulleys of the same diameter. For increased torque and slower speed, you need to use a smaller pulley on the motor (or a larger pulley on the leadscrew).
Incidentally, notice I linked to HTD5 pulleys above? I bought T5 pulleys and then discovered the belts are pretty expensive. The HTD5 pulleys are (apparently) a better choice as they will have less backlash and are easier/cheaper to get hold of.
The Following User Says Thank You to birchy For This Useful Post:
	15-09-2013 #4
Hi again
My X & Y axis are direct drive, using Oldham Couplings, the Milling head, gearbox & motor are quiet heavy, i am not to bothered how fast the Z axis travels, i am more interested in relieving some work on the motor, thats why i thought of using timing belt instead of direct drive, should i use 2:1 or 3:1 Should this be Driver to Driven or Driven to Driver?
Regards
Ray
	15-09-2013 #5
I'd go 3:1 with small pulley on stepper.
If you want to relieve some stress on the motor then use some form of counter balance, either weights or gas struts.Last edited by JAZZCNC; 15-09-2013 at 04:36 PM.
	15-09-2013 #6
Hi All
Again many thanks, believe it or not, that's just what i was thinking of, honest, just had one of those age moments that lasted a couple of hours.
Ray
	15-09-2013 #7
I have pulleys for 3:1 on my Z-axis as well!
However, this interesting response was a reply when I asked the very same question: http://www.mycncuk.com/forums/faqs-p...html#post47446
	16-09-2013 #8
Thanks Birchy.
I had already decided on a key way driven pulley on the Z axis Leadscrew, has the existing shaft has one in, so i will utilise the existing keyway.
Regards
Ray
stepper motors not being driven
By sprint in forum Machine Control SoftwareReplies: 4Last Post: 12-02-2013, 03:42 AM -
2 Motors driven from one driver in parallel
By fozziebear40 in forum Motor Drivers & ControllersReplies: 5Last Post: 12-07-2012, 09:22 AM -
NEW MEMBER: marker pen driven over an 8x4 sheet help.
By Danny in forum New Member IntroductionsReplies: 40Last Post: 02-12-2011, 12:45 AM -
BUILD LOG: 8020 belt driven 3 axis
By compfranon in forum DIY Router Build LogsReplies: 20Last Post: 30-03-2010, 05:06 PM -
BUILD LOG: Belt driven 3 axis machine
By Swarfing in forum DIY Router Build LogsReplies: 14Last Post: 21-02-2010, 10:46 PM
