Thread: Steel rolling
    Hey guys, I'm looking for someone who is able to or have access to equipment to be able to roll 10mm mild steel.
    The steel needs to be rolled into a circle with a OD of 660 width of the steel will be 150mm
    So just to clarify, I need a 150mm x 660 DIA circle rolled from plat plate.
    Unless anyone knows where to get steel pipe with an OD close to 660
    I will attach pictures shortly.
Name:	Rolled steel.JPG
    i2i's Avatar
    Hot finished seamless tube - from stock. mild steel tube
    A fair bit thicker, try ringing them for thinner section.
  3. The Following User Says Thank You to i2i For This Useful Post:
    Wow, ive google and googled it for steel tube, but always ended up sending me to china! thanks i2i see what they come back with.
  5. #4
    Try Googling Barnshaws or Atomic Bending, that's right up their street.
    Neil...
    Build log...here
  6. #5
    Cheers I will contact them on Monday also
  7. #6
    Hi,D-man,we are Machining factory.I think we can produce this one.
    My email:[email protected]
    Please send details to my email.
    Thanks!
    Linda
  8. #7
    Quote Originally Posted by wangxiaorui View Post
    Thanks!
    Linda
    Linda, I don't think your quote would be very competitive once you factor in the carriage to get it from China to here...................
    Neil...
    Build log...here
  9. #8
    Ok.neil.What quantity do you want,let us check.
    You plan buy from your local place?
    Linda
  10. #9
    Linda,
    1. The problem is that I presume this is a 1 or 2 off, even if it was more than that you still would not be competitive unless he wanted a container load.
    2. You seem to be "fishing" for work, this does not go down too well on the forum. By all means advertise your company and provide a link to it with a description of what services you can offer, but DON'T keep replying to peoples adverts saying "we can do this send me the details" as it just gets peoples backs up.
    I must have my "customer service" hat on today as these replies have been remarkably polite...
    Neil...
    Build log...here
  11. #10
    Ok.Thanks neil.Thanks for your teach me.1,you are right.Maybe you would consider the quantity and cost. 2.I am new in this forum.Donot know what i should write is better.Thank you!
  1. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
  2. What is Steel 25BG?
    By Tenson in forum Metalwork Discussion
    Last Post: 03-08-2013, 11:08 AM
  3. 4130 Steel
    By newtoid1986 in forum Metalwork Discussion
    Last Post: 11-02-2013, 03:05 AM
  4. WANTED: Steel Off-cut!
    By Tenson in forum Items Wanted
    Last Post: 27-04-2012, 05:59 PM
  5. New hybrid linear bearing combines rolling and sliding
    By igusUK in forum Rails, Guideways & Bearings
    Last Post: 15-10-2009, 10:00 AM
