    Hi all
    I run a HOBBYMAT BFE65 vertical milling machine c.1984. I am looking to fit anti backlash nuts, but i seem to have hit a problem, Does anyone in CNC land know exactly what the Lead-screws are? i have measured them at 14 mm outside diameter, single start with a 2 mm pitch per single evolution, the problem is i am having difficulty finding out if they are ACME, METRIC or TRAPEZOIDAL, and i can only find 3 mm pitch on the internet (TR14 3)
    Any help on this subject would be very helpful.
    Regards
    Ray
    Ray did you ever get an answer to this?
    .Me
    .Me
    Hi.
    No i did not.
    Ray
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 13 Hours Ago Has a total post count of 807. Received thanks 101 times, giving thanks to others 176 times.
    If the pitch is metric the leadscrew is Trapazoidal(Trapazoidal is the metric version of Acme)
    Not all the pitches are show on the charts i had a look @. I was looking for data for turning an M8 x 2 leadscrew and couldn't find it,fortunatelly i have a tap and will make the nut first and leadscrew to suit.
    Mike
  5. The Following User Says Thank You to mekanik For This Useful Post:
  6. #5
    Many Thanks Mick.
    I have not fitted backlash nuts yet, but this info will be valuable for the future.
    Regards
    Ray
  7. #6
    Hi Ray,
    Why not replacing the leadscrew all together with a known diameter / pitch?
    Trapezoidal screws are fairly cheap these days.
    RNR
  8. #7
    mekanik's Avatar
    It's all well and good doing that but as a rule there's an indicator dial on the end of it so you need to make a new one. i am replacing a 1mm pitch screw so bought 2mm pitch tap so can go off half a division of dial. As it's for the topslide it only gets used for doing facing cuts and infeed when screw cutting. you could get a 4mm screw and do the same.
    Mike
  1. VFD retrofit Hobbymat BFE65
    By manofgresley in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2013, 05:07 PM
  2. Hobbymat BFE65 Conversion - Gearing my Steppers?
    By jamezwarner in forum Gantry/Router Machines & Building
    Last Post: 06-09-2011, 06:08 PM
  3. Source of multi-start ACME or Metric Trapezoidal Leadscrew and Anti Backlash Nuts
    Last Post: 16-03-2010, 10:11 PM
  4. Commercial Sieg X1 anti backlash nuts ?
    By cweeks in forum Milling Machines, Builds & Conversions
    Last Post: 28-05-2009, 06:41 PM
  5. Anti-backlash bearings for acme screws
    By RichardPiper in forum Lead Screws, Nuts & Supports
    Last Post: 16-06-2008, 08:34 PM
