    Comes complete with a shiny laser reflective overcoat...
    Hand-operated laser cutting for nuclear decommissioning - YouTube
    Why ?
    Got to be very expensive and will only be able to do thin stuff, no castings etc
    Any reason why a plasma which is far cheaper and more powerful can't be used ?
    John S -
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 375 times, giving thanks to others 9 times.
    The only reason I can think of is the laser doesn't need to be that close to what you're cutting compared to a plasma torch.
    Bugger there goes another sale, I will never get rich at this rate
    I think you will find plasma requires a wire connection, a metal target and close proximity so as a general wrecking tool this does have an advantage...
    Concentrate on the toy value
    I like how they put an LED on on the 'gun' to show that the laser is on, just in case you didn't notice.
    I think they've been watching too much star trek...
    They should put sights on it so you can use it as a fly swatter.
    Didn't think much of the wobbly lines they were cutting.....in the films they manage much better straight lines
    Neil...
    Build log...here
    It might take a lot of practice to get the depth of cut just right? How about a hand-held water-jet?!
    I wonder what it's range is - new sniper-gun?
    To use the oft quoted phrase "Will it cut ali"?
    The beam will diverge - how much determines the range as after a certain point the intensity will no longer be sufficient to have the desired effect.
  1. Replies: 12
    Last Post: 25-05-2013, 12:41 AM
  2. MIT Students Hand Held CNC Router
    By mekanik in forum Marketplace Discussion
    Last Post: 26-09-2012, 12:49 PM
  3. Laser cutter
    By John S in forum Laser Machines & Building
    Last Post: 02-06-2012, 02:16 PM
  4. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
  5. Convert Wood Lathe from hand held tooling
    By Wobblybootie in forum Milling Machines, Builds & Conversions
    Last Post: 14-02-2010, 11:53 AM
