    Getting flats on my circular pocketing. All sizes of circle affected, more or less on the north quadrant as viewed from operator position. Running Mach3 on Seig X3.
    Seems like a software/setting problem? I seem to remember this coming up before. But can`t recall where.
    Any leads appreciated.
    Got ballscrews fitted ?
    Flats on circles are normally mechanical, slack in nuts etc.
    You can compensate in mach under Backlash compensation but it's a cludge.
    For one it doesn't work correctly and secondly if there is free play, even compensated for, the cutter can grab and pull the work.
    John S -
    slack in nuts etc.
    John's the leading expert when it comes to "Slack Nuts".!!. . . . Viagra works better than backlash Comp Hey John. .
    Agree with him thou 99% sure it will be Sloppy nuts or loose couplings.!!
    Check your software for overlap values or lead in lead out and also cutter comp activation points
    Yup Jazz is right, that viagria isn't all it's cracked up to be.
    Gave mine to me grandad, stops him rolling out of bed at night
    John S -
    Ah right! - To get good circles. You need to securely tighten the main casting to Y axis ball screw journal.
    My "nuts" are now secure in a steel thong, but now have the problem of walking a bit odd!
    Apologies to have wasted any ones time.
    My father-in-law had Viagra to stop him pissing on his slippers.
  1. conect software what do these 4 do, pocket, drilling and profile?
    By windows20 in forum Machine Control Software
    Last Post: 31-08-2016, 02:20 PM
  2. Feeds and speed guide/pocket book
    By maritimesbob in forum Marketplace Discussion
    Last Post: 10-11-2013, 08:38 AM
  3. Another screw problem
    By Swarfing in forum Marketplace Discussion
    Last Post: 27-03-2013, 08:24 PM
  4. Problem with X
    By gorbo in forum General Discussion
    Last Post: 24-02-2011, 04:33 AM
  5. Z Problem
    By airwolf in forum Machine Discussion
    Last Post: 10-11-2009, 07:08 AM
