    I need to cut a thread on (say) 30mm brass rod that engages with m20 threaded rod (2mm pitch?). The 30mm is only a nominal diameter at this ideas stage. Anybody got any formula to calculate the diameters according to the pitch and number of starts on a thread ?
    OR am I being stupid, will a 2mm pitch external thread on just fit regardless of the diameter of each rod ?
    I only did O level maths over 50 years ago, so don't go into much beyond basic trig svp.
    I have a mini lathe (in bits at the moment) with a metric thread cutting leadscrew btw.
    Cheers,
    Rob
    All threads have standard drilling and shaft sizes which MUST be followed. So for a standard M20 x 2.5 coarse thread, you need to drill out 17.5mm before tapping. The O.D. of the shaft is irrelevant as long as it's bigger than the thread diameter. For male threads, the O.D. is 20mm, so if you had a 30mm shaft, you'd have to turn part of it down to 20mm before using a threading die. Tap Chart Metric Threads
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 13 Hours Ago Has been a member for 9-10 years. Has a total post count of 788. Received thanks 97 times, giving thanks to others 176 times.
    Hi Rob Can't get my head round what you are trying to do ?
    You can put a 2mm pitch thread on practically any O.D. (within reason)just make the depth correct as per your Zues book, lots of manufacturers make odd size threads on some of there equipment but they would manufacture special taps to match,are you trying to make a nut ? or a male thread on 30mm bar ? I do have some info on specials but i think they are Imperial, not sure if there is info in Machinerys Handbook, i have seventeenth edition.
    Mike
    Yeah, it's not totally clear what you are trying to achieve? If you decide to search for the (essential!) book mentioned above, it is ZEUS and not Zues. Zeus Precision Engineers Metric Data Charts Reference Tables Book Drill/Threads | eBay
    Threads may not be the correct solution for your problem, so maybe you could tell us what you are ACTUALLY trying to do so we can bounce ideas of each other?
    OK - here's the problem : Velleman make a 3D printer kit for £700, it is cheap, but nasty. The Z axis is a piece of threaded rod with a standard nut. That strikes me as sloppy by design and I am looking at ways of improving the design by creating a nut with three bits of threaded rod with ends turned to fit into bearings (3x10x4), putting the whole thing together with some end caps so the thing becomes a sort of ballnut that fits on the existing Z axis. I am playing about with the whole idea at the moment. That's what I do (play with ideas, since I lost interest in playing with myself ages ago). I didn't want to go public as the idea may be plain stoopid and I don't want the position of Forum Clown, even if it is vacant.
    Having said that the Velleman K8200 kit is crap, it still looks like a cheap way in to 3D printing. You get a lot for the money.
    Maybe someone has already done what I am trying out and got far enough to reject the results, or maybe you can buy one from China
    Rob
    mekanik's Avatar
    Hi Rob
    Gotcha now, i was looking into this the other weekend on one of the US CNC forums for a cheap ballscrew alternative. so all you need is 3 pieces of the bar threaded with 2mm pitch, diameter will have to be bigger than the smallest bearings you can get unless you were just going to put oilite bushes in the end plates, still relying on accuracy of the studrod but as it's rolled it should be near enough for making bits of plastic.
    Mike
    Rob
    Nope, someone has just filled it
    John S -
    Sorry John, I meant even if it WERE vacant.
    mekanik's Avatar
    Had a picture of a roller screw that i had saved when i was looking @ them the other week but dumped it the other day when having a clear out of my desktop.think it was CNC zone but it was a huge thread.
    mekanik's Avatar
  11. The Following User Says Thank You to mekanik For This Useful Post:
  1. What do you think of this multi heads CNC router machine?
    By mornrose in forum Manufacturer News
    Last Post: 08-08-2013, 02:08 AM
  2. Multi wire plugs
    Last Post: 26-11-2012, 01:47 PM
  3. Replies: 0
    Last Post: 10-06-2012, 07:59 PM
  4. WANTED: 4 x 8 cnc router wanted and multi borer machine
    By wyndham in forum Items Wanted
    Last Post: 14-09-2011, 10:03 AM
  5. Multi stepping
    By ptjw7uk in forum General Discussion
    Last Post: 23-07-2009, 03:19 PM
