    Hi I am looking to upgrade my cnc router to an aluminium cutting bed with tee slots.
    I have seen lots of machines which have this sort of cutting bed, made up of 3 or 4 widths across the bed depending on the width of the machine, but it is not easy to find a suitable source in the UK.
    I have tried the bosch agents but I would need to buy a 5600mm length minimum, their profile is 18mm x 160mm wide or 22mm x 160mm wide so Iwould need 3 off 1 metre lengths
    The bed of my machine is 480 x 1000mm long I could fit up to 600mm wide if need be, any suggestions?
    asbo's Avatar
    Lives in Norwich, United Kingdom. Last Activity: 05-10-2015 Has been a member for 4-5 years. Has a total post count of 46. Received thanks 8 times, giving thanks to others 1 times.
    KJN cut their profile to whatever size you want and deliver it via courier. I dunno if they have the size you want but, having used them in the past, I can say their service is good.
    Try these too
    http://www.extrusions-aluminium.co.u...xtrusions.html
    http://aluminium-profile.co.uk/]KJN - Suppliers or Aluminium Profile and Accessories
    http://www.valuframe.co.uk/]Valuframe - Aluminium Extrusions > Aluminium Profile > Aluminium Extrusion > Aluminium Profiles >Aluminium Profile Systems
    http://www.motedis.co.uk/shop/Slot-p...:::1.html]Slot profiles
    http://www.metallin.co.uk/shop/]Metallin - On-line store for Aluminium Profiles / Aluminium Extrusions / Aluminium Profile / Aluminium Extrusion
    http://www.8020cnc.com/]DIY 80/20 Aluminum Extrusion CNC Machine | 8020CNC.com
    http://www.boldman.co.uk/aluminium-p...tem/]Aluminium Profile Systems | Boldman | Leading manufacturer of Aluminium Profile Solutions
    http://www.damencnc.com/en/component...s]DamenCNC.com
    http://www.zappautomation.co.uk/en/6...ium-extrusions
    http://www.wdsltd.co.uk/product/4644...-590]Aluminium Sub Plates MiteeBite (WDS 590), Sub Plates | WDS
  4. The Following User Says Thank You to EddyCurrent For This Useful Post:
  5. your link to zapp is error 404.
    this is the correct link.
    Isel Aluminium Extrusions - Zapp Automation Ltd
    and here
    Kanya Aluminium Extrusions - Zapp Automation Ltd
  6. The Following User Says Thank You to Gary For This Useful Post:
  1. Small desktop mill/router for cutting <=6mm aluminium
    By matt-b2 in forum Marketplace Discussion
    Last Post: 08-12-2013, 12:04 AM
  2. Profile Cutting Options BobCAD CAM
    By aldepoalo in forum BobCAD-CAM
    Last Post: 25-06-2013, 08:10 PM
  3. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 08:54 PM
  4. Aluminium Profile - ValuFrame?
    By Tenson in forum Marketplace Discussion
    Last Post: 28-06-2012, 01:20 PM
  5. Tapping Aluminium profile
    By jonbabbz in forum Tool & Tooling Technology
    Last Post: 28-05-2012, 07:09 AM
