    Whats the easiest, preferably free, way to convert a gerber file to a dxf. I want to mill out a pcb which I have a gerber file for.
    Is it a straight convert process or does the dxf have to be redrawn/tidied up after the conversion process?
    A while ago I had a quick look and didn't find a program to convert gerber to dxf. So instead I just used one of the programs that converts gerber to an image, then used a CAD program to vectorise it and added in circles for the holes 'manually'. Fortunately there weren't many holes...
    CamBam will import gerber files - no idea what it does with them but the free demo gives you 40 goes before you have to buy so may be worth a try.
    Quote Originally Posted by FatFreddie View Post
    +1
    I do this all the time...export my PCB layout as a gerber (from eagle), open the associated gerber file in cambam, I thenadd in all the other MOP stuff required before generating my g-code.
    Cambam will allow you to export the imported gerber file to dxf.
    Thanks guys. I've got cambam so I will give it a go. Not tonight though. Its bacardi and irn bru time!!!!!
  1. Gerber system 48
    By martin54 in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2013, 11:35 AM
  2. Where to get PCBs made in reasonable quantities?
    By Jonathan in forum General Electronics
    Last Post: 07-09-2013, 04:25 PM
  3. NEW MEMBER: PCBs - desktop CNC - Hi from salisbury
    By Plod in forum New Member Introductions
    Last Post: 07-09-2013, 08:34 AM
  4. Rebuilt gerber 48 value
    By martin54 in forum Machine Discussion
    Last Post: 29-07-2013, 04:34 PM
  5. How hard is it to make diy PCBs if youre a Noob ?
    By Fivetide in forum General Electronics
    Last Post: 05-04-2013, 11:10 AM
