Thread: Harmonica Case
30-03-2016 #1
It is my harmonica teachers 70th birthday in April and I thought I would have a go at a harmonica case to fit a Seydel Saxony harmonica.
The oak cost me £7.50 for an 8ft length of 3" x 1".
The first try ended up showing me that my MD machine was not cutting square, so I spent a day with a large engineers square (the large engineer wants it back !) and a dial gauge to find out where the skew was. I found it and corrected it, but it is a design weakness, so I have to be wary that it could skew again !!!!
I used most of the oak to make firewood, and when I got the first good cuts I changed the design. So none left really.
After skimming the top, cutting the cavity and outside profile for both the bottom and the top, I cut a jig in softwood and put the pieces in it with some double sided tape and skimmed the faces with my new Chinese bottom cleaner (£2.08) before cutting the recess for the brass plate.
I attacked it with sandpaper and gave it a coat of sanding sealer before bringing it up to a finish with wire wool and wax. There was a slight disaster when one of the hinge screws broke and I had to drill it out, but it taught me to lubricate the screws to make them go in more easily (ooh err missus !). Inside I lined it with strips of adhesive foam and a top layer of black self adhesive felt. I CNC cut a perspex template and used a scalpel with a new blade to cut them out. My experiments with a drag knife were a failure !
The brass plate was engraved with code generated with Vcarve, but the woodwork was drawn with AutoCAD and converted toGcode with EstlCAM V8.
There were a few fails and bodges, but otherwise I am pleased with the end result.
30-03-2016 #2
Very nice Rob. It's a credit to you. I take it you have used brass screws in the oak as steel one's can make the oak go black
30-03-2016 #3
Looks good he should be well happy, shame he won't be able to play for a while, 70 candles gonna leave him short on blow!
30-03-2016 #4
30-03-2016 #5
I agonised about that for hours, then decided "sod it" (or words to that effect). The only screws I could get were steel with an antique brass finish, so I put them in a charred screw socket with plenty of wax in the socket.
Actually Clive I am surprised you didn't spot the big mistake. I'll PM you what it is
01-04-2016 #6
Really nice and now intrigued on the "big mistake" - the hinges not flush fit perhaps?
My CNC Projects: https://www.youtube.com/imadethisoncnc
01-04-2016 #7
01-04-2016 #8
RFQ: Prototype keyboard case - CNC and laser
By Photekq in forum Projects, Jobs & RequestsReplies: 1Last Post: 26-05-2013, 08:18 PM -
Drivers,BOB and PSU are in a PC case, do i earth the case
By deannos in forum Motor Drivers & ControllersReplies: 4Last Post: 27-11-2011, 03:43 PM -
RFQ: Project Case End Plates Require Making
By flipflop in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-08-2010, 09:03 AM -
PC case control box
By lateAtNight in forum Electronic Project BuildingReplies: 18Last Post: 02-02-2010, 03:27 PM -
Controller box from PC case
By Smiler in forum Electronic Project BuildingReplies: 15Last Post: 24-12-2008, 03:46 AM
