Hello all,
I already have the stepper and drives and I'm not sure about the PSU current and voltage.
My four steppers (chinese) have the following specs (if real): nema34, 66mm length, 4A, 0.6Ω, 1.6mH and the drives (chosen to fit my budget) are based on the THB6064 chip: 4.5 A absolute; 4.0 A operating range; 50V absolute maximum; 42-45V? operating.
The toroidal transformer will be manufactured to my specs.
How about two sec. windings at 33V and a total of 630 or 750VA?
Why two windings... I will most probably upgrade the drives to 80V in the future and it will be nice to be able to reuse the toroid.
I also want to build a B/C head or a rotary axis soon and to be powered from the same PSU.
Any help will be greatly appreciated
28-10-2013 #2
I bought mine here;
Chassis mounting toroidal transformers
Two 33v windings in series will give you 66 * 1.414 = 93v DC which is too much.
A 625VA 2x24 would be better, this would give approx 34v dc in parallel, 68v dc in series
Standard Range Toroidal Transformers: CM0625224: 625VA 230v to 2x24v
28-10-2013 #3
Why Nema34 and not 23s?
33v secondary will give 43 to 48v on supply variation which doesn't leave much room for regenerative dumping on a 50v drive. I'd go for 30v secondary.
Don't see how you'd reuse the toroid on an 80v drive. 2*33*1.414-1=92v +/- 5%, you need 2 x 27v secondaries for maximizing an 80v drive.
28-10-2013 #4
When I'll need to reuse the toroid for 80V I'll take out some wire from the secondary.
Not sure. I think it will give me more torque at high speeds (1.6mH nema34 vs. 3.5mH nema23). Plus the robust 14mm shaft.
Actually I want to push the drive chip to the limits as the chip protections are quite good. But I'll probably go with 30V.
Not sure about the voltage drop on load. Will it be significant?
28-10-2013 #5
Best of luck will all of that.
28-10-2013 #6
I've read and remembered this rule somewhere on the CNCZone (I think): "Never apply voltage that is greater than 32 times the square root of the motor inductance in mH.
BTW, where do you get the 6064 drivers from? I am looking for the chips only but without success.
28-10-2013 #7
28-10-2013 #8
Hmmm, have you ever tried it? I've done it and rewound them... not recommended, and very hard if you have multiple secondaries.
Oh dear If they're the motors I think they are then you're starting at 2.2Nm rather than the 3.1Nm of a decent modern Nema23 and that 14mm shaft is just shed loads of inertia you dont need (as is the massive coupler) especially if you need to run it that fast. There are plenty of Nema23 with low inductance windings.
Depends on the spec of the toroid, but the load isn't constant... if only one stepper of the 4 is running then its driver could be more susceptible..
29-10-2013 #9
Probably I'm wrong with my nema34 steppers but I've seen a lot of different Chinese specs and I do not trust them, and the ones sold in Europe and USA have the same Chinese specs sheet... and they are so optimistic compared to the good brands.
The 3.1Nm has too high inductance for my 42V drives.
I have missed the rotor inertia 560g·cm2 vs. 850g·cm2. High speeds without good acceleration are worthless. Will see them performing in real life... to many calculations for a hobby engineer.
Any recommendation regarding the PSU power? I have read somewhere that 60% of the steppers/drives current is enough for a toroid. Is this true?
And another probably dumb question.. with 25A at 30V AC will I have 25A or 18A at 42V DC?
Lucas from Belgium offers DIY kits of the drives and BOB with very good documentation. I enjoyed soldering the components.
THB6064 drive kitLast edited by paulus.v; 29-10-2013 at 01:21 AM.
29-10-2013 #10
yet we all use them because the inductance effect determines the corner speed of the motor, the speed where torque drops off, and a good mechanical design should never operate above the corner speed, at least not when cutting.
Yes, it's generally true and often much less in practice. But you do need enough bulk smoothing capacitance to cope with the occasional peak demand.
25A @ 30V AC will give you 25A @ 42V DC
.Last edited by irving2008; 29-10-2013 at 07:09 AM.
There are currently 76 users browsing this thread. (0 members and 76 guests)
By Carlb1058 in forum General ElectronicsReplies: 7Last Post: 17-08-2013, 06:54 AM -
Stepper Drives
By GTJim in forum Marketplace DiscussionReplies: 4Last Post: 05-04-2013, 12:05 PM -
Nema 34 Stepper Drives,
By drumsticksplinter in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 03-04-2013, 04:20 PM -
Toroidal transformer voltages - sanity check needed!
By m_c in forum General ElectronicsReplies: 16Last Post: 03-10-2011, 08:34 PM -
Contactor sizing?
By Swarfing in forum General ElectronicsReplies: 5Last Post: 27-12-2010, 08:58 PM
