17-11-2013 #3
I think start by giving it a thorough clean, then oil it. It looks like you've got it outside at the moment so you definitely want to put oil on the bed and get it indoors asap to stop it rusting.
It depends if you need to convert it to mach3 or not. If the existing system still works, then you'd save a lot of effort just leaving it as it is.
Easiest option is just remove everything from the control box and start again, but you might be able to save a bit by re-using some parts. For instance the power supplies might be suitable for modern stepper drivers, so check their voltage and current ratings if you can. Look at what the spindle (which oddly enough I can't see in the photos?) is connected to - there's likely an encoder and some sort of driver for the motor. Also see what the toolchanger connected to.
From your pictures it looks like the stepper motors are Nema34. Have you tried googling the part numbers on them to see if you can find a datasheet? If you're lucky the current ratings might be written on them.Last edited by Jonathan; 17-11-2013 at 06:59 PM.
Boxford TUD conversion Mach USB
By Stucncusb in forum Boxford LathesReplies: 1Last Post: 21-06-2016, 09:40 PM -
Mach lathe spindle speed control
By GeoffV in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 21-05-2014, 08:34 AM -
WANTED: Looking for a MKII Boxford duet for conversion to Mach 3
By BlueBot in forum Items WantedReplies: 0Last Post: 20-05-2014, 06:07 PM -
DYNA Mechtronics Dyna Myte 3000 lathe
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 12-11-2013, 08:05 PM -
800x600 Mach 3 Lathe screens?
By cooliced in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 22-08-2010, 10:19 PM
