    Hello All,
    I have a set of SBR16UU linear bearing blocks. There are four mounting holes and in the centre a set screw.
    Before I mount the bearings, I want to know if I need access to the set screw. What is it for? I suspect it is for removing the
    linear bearing from the mounting block. But it could be for some kind of adjustment (I think this is unlikely but worth asking
    before I make the screw completely inaccessible. Thanks for any help.
    Neil.
    Just in case my original description was vague, I have added a marked-up picture of a bearing block similar to mine.
    Thanks,
    Neil.Click image for larger version.
    The center hole is primarily to keep the bearing in place. The one in the side is used to try and eliminate play in the bearing.
    Thanks Jonathan, That implies that I can cover the central hole and not regret it later when I have to strip the machine the down to make an adjustment.
  1. Small footprint turning centre
    By Hellfire in forum Marketplace Discussion
    Last Post: 28-08-2013, 10:13 PM
  2. Centre tap transformer?
    By veedub1955 in forum General Electronics
    Last Post: 15-05-2012, 11:10 PM
  3. Turning centre retrofit help/project on a Mazak/Yamazaki
    By spluppit in forum Mazak, Yamazaki Lathes
    Last Post: 13-11-2010, 01:43 AM
  4. Broken centre drill recovery
    By Robin Hewitt in forum Tool & Tooling Technology
    Last Post: 25-01-2010, 10:53 PM
  5. Centre drilling with lathes...
    By HankMcSpank in forum Milling Machines, Builds & Conversions
    Last Post: 12-09-2009, 12:01 PM
