Thread: Limit and Home Switch Choice
01-12-2013 #21
Along with this thread and my own I can see there is never going to be a consensus of opinion with regard to limits and emergency stop circuits. All anyone can do is see what others have done and choose the bits that suit them best.
Here's how mine is going to be, I just changed a few things this weekend and will upload my 'as build' drawings later.
My emergency stop circuit consists of a big red button on the control panel and another in series on the machine, the limits are also in series with these buttons and a relay in the VFD indicating a fault condition is also in the circuit. Everywhere I have worked the limits, which I'm going to call 'ultimate limits' because that is what they are, always form part of the emergency stop circuit. These limits should never be activated, Mach3 has 'soft limits' for example that should operate first (don't know about Linux system).
I'm also using a PILZ emergency stop relay (@birchy it only cost £25 on ebay) so when the emergency stop circuit is activated the relay de-energizes removing power to the stepper drivers, sending Mach3 an E/stop signal, stopping the VFD by using a special emergency stop function and a Safe Torque Off (STO) feature.
The system can only be reset when all the relays and buttons are in the correct position and the VFD has been reset.
I also have a ‘stop’ button on the control panel that sends a STOP signal to the VFD and also stops Mach3 running. There is a ‘pause’ pushbutton that sends a ‘FeedHold’ signal to Mach3, it also stops the VFD.
To recover from a stop or pause condition a ‘reset’ button is pressed which also sends Mach3 an OEM signal to activate its RESET button and the VFD powers up again. Any time Mach3 is stopped it activates an Enable signal to stop the stepper drivers. Also in series with my pause button is a spindle over temperature switch and in series with my stop button is a relay that indicates if any of the AM882's have gone into alarm.Last edited by EddyCurrent; 01-12-2013 at 10:06 PM.
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Another Home - Limit switch question
By Cube3 in forum General ElectronicsReplies: 6Last Post: 26-12-2013, 07:51 PM -
FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
By Shinobiwan in forum Items For SaleReplies: 6Last Post: 02-02-2013, 10:54 AM -
Limit switch Cable ...
By Wobblybootie in forum General ElectronicsReplies: 3Last Post: 17-01-2011, 04:37 PM -
Limit switch's - best configuration?
By HiltonSteve in forum General ElectronicsReplies: 16Last Post: 13-08-2009, 01:26 PM
