    Hi all.
    I recently fitted a second HDD to my DELL Precision 380 Desktop pc. (My aim is to run the MACH 3 software on the 2nd HDD) On re booting, Windows found the 2nd HDD and configured it ok. My problem started when a came to download the software from the CD Drive, nothing happened, this is what i checked out : -
    The Hard Drives are SATA, drive 0 & drive 1. CD ROM is connected by IDE ribbon.
    1) LED on front of CD ROM tray flashes.
    2) CD is spinning OK.
    3) CD tray ejects by pressing eject button.
    3) Entered "My Computer" no CD icon showing.
    4) Entered "Device Manager" there is no CD drive Listed.
    5) Re started PC, pressed F2 and entered BIOS set up.
    7) Scrolled to Boot Sequence it reads "On Board or USB CD ROM "Not Present"
    8) In SATA setting, tried all 4 positions (No Change)
    8) Tried spare IDE cable (No Change)
    9) Tried spare, known good CD ROM Drive (No Change)
    10) CD ROM jumper is at CS
    11) Tried many variations of Jumper position (No Change)
    HELP!
    Ray
  2. if you disconnect 2nd HDD does it find CD?
    Sounds like IDE controller disabled in BIOS
    Irving 2008
    Many Thanks.
    While i was following your advice on whether the IDE controller may be disabled, i was in BIOS @ the Drives section marked 0 - 6, my Floppy drive is OFF, i have no Floppy drive. 0 is my 1st HDD and therefore was ON, 1, is my 2nd HDD and again is ON. Drives 2 - 6 were OFF, though it stated that the Factory Default setting is ON.
    So i turned all the drives to ON, everything now works fine, cannot explain it, but i could not find were the IDE controller is, but thank you anyway.
    Regards
    Ray
  4. You're welcome. on my system drives 0,1 are SATA, drives 2,3 are IDE1, drives 4,5 are IDE2
  5. The Following User Says Thank You to irving2008 For This Useful Post:
  1. How to find first job as CNC operator ?
    By malzyk in forum Opportunities Available & Sought
    Last Post: 07-09-2013, 03:21 PM
  2. NEW MEMBER: Where to find new job opportunity in Onsite machining
    By navinmg6585 in forum New Member Introductions
    Last Post: 09-05-2013, 12:54 PM
  3. how can I find a precision solution partner?
    By sysupplier in forum Manufacturer News
    Last Post: 01-09-2012, 09:19 AM
  4. Trying to find a kit or plans to build.
    By don_jarr in forum Gantry/Router Machines & Building
    Last Post: 16-06-2011, 03:28 PM
  5. got a problem cant find belts for lathe
    By Scott in forum Machine Discussion
    Last Post: 08-09-2010, 12:35 PM
