Thread: Breakout Board
10-12-2013 #1
Hi guys im gonna make the move and wire in the new chinese 2.2kw spindle that i bought, im just looking for recommedations on breakout boards that will switch on the spindle though mach when i run a toolpath. All help greatly appreciated. Dont mind the spelling.
I use these, the SPMODv2 spindle board plugs into the bob so no extra wiring, both work great, I'm using Mach3.
It's setup so that an M3 instruction closes the spindle relay and for example S6000 makes the spindle rotate at 6000 RPM.
If you decide to get these go for the one with 2 relays, these use pins 14 and 17, I can't imagine you would want counter clockwise so the relay on say pin 14 could be used for other purposes as it can handle 240v ac at 10 amps.
SYSTEM1
System4Last edited by EddyCurrent; 11-12-2013 at 09:40 AM.
12-12-2013 #3
Thanks eddy ill have a look at this,
Thanks for your reply.
breakout board usb or parallel
By crossleymarko in forum Motor Drivers & ControllersReplies: 13Last Post: 30-07-2013, 12:44 PM -
Breakout Board Comparison
By 200thhorseman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 27-03-2012, 12:28 AM -
FOR SALE: PMDX-122 Breakout board
By IN-WondeR in forum Items For SaleReplies: 0Last Post: 14-12-2011, 04:05 PM -
Breakout Board
By croy in forum Electronic Project BuildingReplies: 10Last Post: 18-08-2011, 07:50 AM -
eBay: CNC Breakout board cheap - that will do me !
By Lee Roberts in forum Items On eBay UKReplies: 9Last Post: 14-08-2009, 05:52 PM
