    I did say I was no good at fitting ballnuts which is why I asked you to fit them for me. Guess you forgot.
    I did my best, but it had to go on over a 12mm shaft with grooves in it for my grub screws. I could see balls were going to drop in the grooves so I wrapped it, slid it on and started screwing. It was not happy.
    It seized up PDQ, I jiggled and joggled trying to persuade it on but it's all gone horribly wrong. The milling machine is in pieces. I have half the nut in place, probably missing 2 or 3 balls, and the other half is in a box.
    Think I may have found the problem, could be a slight burr where they machined the end to a shoulder.
    Questions:
    Is it possible I can reassemble the nut?
    Is it possible to top up the end circuit 2 or 3 balls if I wind the shaft back?
    Hot tips for assembling the second shaft?
    Had to happen just before the Bank Holiday <angst> but it's the first time I've had a few days free
    Much ta
    Robin
    The thought of no mill for the Bank holiday spurred me on, I actually have very little to lose.
    I have reassembled the second nut, deburred the thread and fitted it.
    I have 5 balls left over from the first nut.
    New question
    Is it worth taking the other nut apart for 5 balls?
    Guess I will find out if it feels right when I fit the next one
    Robin
  3. Sorry i did forget, send it all back to me and i will fit it.
    Gary
    New question
    Robin
    Well, I can't be all that miffed because I just bought another one for the Z
  1. Congratulations to Gary @ Zapp
    By JAZZCNC in forum General Discussion
    Last Post: 21-09-2013, 06:44 PM
  2. Ok, I'm stumped. Question for Gary (ZAPP)
    By Smiler in forum General Electronics
    Last Post: 06-03-2009, 10:47 AM
