Thread: Tonsen 4 Axis Controller/Bob
04-01-2014 #11
I have this BOB in a machine i purchased a couple of months back, so far ive had no problems with it. Although im not doing anythign greatly extravagant with it. I would like to add home switches to it though and maybe a touch off plate but so far ive not found where to connect the wires.
Any help would be appreciated
Sean
04-01-2014 #12
The Following 2 Users Say Thank You to Pointy For This Useful Post:
04-01-2014 #13
Ok this is going to sound dumb but what does optoisolation do? lol sorry but im very new to this. I will probably be connecting microswitches as home switches, although i have some prox sensors i think in the garage which need 8v according to the packing .
04-01-2014 #14
04-01-2014 #15
04-01-2014 #16
Just think of it like this...
If you have a major malfunction and 240v gets sent to your parallel port, it will probably fry the port and motherboard. Opto-isolation helps to prevent that.
Having said that, I have been running my home/limit switches without isolation on the Tonsen BOB for the last 6 months without issues. I have however just built the opto-isolated addon board to hook up to the Tonsen BOB, I just haven't had time to test it properly. Now that the Christmas malarkey is out of the way, perhaps I can get to test it.
Regards,
Les
05-01-2014 #17
05-01-2014 #18
It's something I am designing myself, but be warned that I am no expert and this is just a hobby for me. I started a thread here to discuss the board, but the schematic shown there is the 1st attempt and contains errors. Once the board is tested I will post the final schematic.
Regards,
Les
23-01-2014 #19
I have a 3040T CNC Chinese and also I want to connect limit switches to Tonsen ....
how the fuck ..... I can not man ..... : (
02-06-2014 #20
Hi all, I also have one of these Chinese Wonders (It's a Wonder that it works!) with the Chinglish Manual and misspelled PCB designates. For my efforts I decided to fit Home/Limits to the X, Y, & Z planes which went quite smoothly until I inspected the I/O Board.
So I set about to bring this into line with half decent components. I upgraded both the 5v and 15v Regulators. Changed the polarity protection diodes for 3A shottkies which have a much lower forward voltage drop than the !N4007’s.
I also changed all the electrolytic’s for 108° low ESR, replacing the 407µF with a 1,000µF The PCB has all the locations needed to fit 5 Opti-Couples and the pull-up resistor network needed for the home/limit switches.
I thought I was doing ever so great and about to do a bit of ‘Yankee Back Patting’ as I connected everything up and switched on..
This time the Spindle Motor didn’t Rev it’s nuts of as usual and the System Fan did not work.... Yep, you guessed right I miss-connected the Fan and Spindle Motor Controller. No big deal as I didn’t see any ‘Smoke Escape’ 1 However, putting 15V directly across the Anode and Cathode of the Motor Controller Opti-couple ensured its demise.
Whilst I was investigating the possibilities of any further damage I rung out to continuity the return line from the connector to the Parallel Port Pin 1.
The Drawing Les, (Pointy) has painstakingly provided is a great help apart from the Motor Line from Pin 1 is connected to the 5v Line via one of the 330R pull-ups, and the second connection to ground. This is incorrect. Pin 1 from the parallel port connects directly to the Opti-Couple on the Motor Controller Sub Board. Be very careful when tackling any problems with the Motor Controller Board It is connected directly across the Mains with enough current to blow your hat off !!
Scoping the Signal, DC Lines, and I/O lines shows that my efforts in upgrading the components has paid off with reduced electrical noise.
1As the Mach3 Manual says, ’Contrary to belief Electronic Components work with Smoke. There is no documented evidence that and device has ever worked once the smoke has escaped’
FOR SALE: Galil 1880 8 axis PCI motion controller
By Boyan Silyavski in forum Items For SaleReplies: 1Last Post: 03-06-2014, 07:39 PM -
eBay: Galil DMC-1580 Motion Controller 8-Axis
By Boyan Silyavski in forum Items On eBay UKReplies: 1Last Post: 25-12-2013, 10:30 AM -
Reversed axis on a AXYZ 6010 after installing DNC controller software...
By RickyThunders in forum Machine Control SoftwareReplies: 1Last Post: 12-02-2013, 03:56 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
