Page 6 of 12 FirstFirst ... 45678 ... LastLast
  1. #51
    cimi's Avatar
    Lives in taglio di po, Italy. Last Activity: 25-10-2015 Has been a member for 2-3 years. Has a total post count of 21.
    My is 3040T and the spindle is a ER-11
  2. #52
    Quote Originally Posted by cimi View Post
    how to reverse the rotation of the spindle?
    Why would you want that ?, the collet nut is designed to rotate forwards, i.e. it is trying to tighten all the time.
  3. #53
    cimi's Avatar
    For my tools...
    because the blades of the tool are down...
    They cut in opposite side..
  4. #54
    I've not seen those, all I've seen are 'up spiral' and 'down spiral' cutters but they all rotate in the forward direction.
    http://www.trend-uk.com/en/UK/trend/...ledge&id=15884
  5. #55
    cimi's Avatar
    my turn in the clockwise direction.... it is right that there has to turn in that direction??
    thanks for the reply me man...
  6. #56
    Looking down on the machine all cutters should turn in the clockwise direction, same direction as a drill would. The up and down spirals are in opposite direction but they both cut in the clockwise direction.
    Did you look at the link above to trend-uk.com ?
  7. #57
    cimi's Avatar
    then I bay something wrong... :(
  8. #58
    Ok so lets first determine which way your spindle is actualy spinning.? It should be spinning in the clockwise direction does it.?
    Can you show the cutters.?
  9. #59
    cimi's Avatar
  10. #60
    cimi's Avatar
    instead the cutting tools have in counterclockwise
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 04-12-2016, 11:16 PM
  2. BUILD LOG: From Chinese to Taffynese
    By Carlb1058 in forum DIY Mill Build Logs
    Last Post: 08-07-2013, 11:03 PM
  3. WANTED: 2.2 KW Chinese Spindle
    By Chaz in forum Items Wanted
    Last Post: 17-06-2013, 09:03 AM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 07:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 05:20 PM
