Page 8 of 12 FirstFirst ... 678910 ... LastLast
  1. #71
    Tutte le frese hanno bisogno del motore a ruotare in senso orario. Stai dicendo che c'è un problema con il vostro motore e non è possibile farlo anche in senso orario?
  2. #72
    cimi's Avatar
    Lives in taglio di po, Italy. Last Activity: 15-09-2019 Has been a member for 7-8 years. Has a total post count of 21.
    Sì... come posso farlo girare in senso orario??
    E poi a te come ti sembra e giusto che il mandrino gira in quella direzione??
  3. #73
    Si tratta di una nuova macchina ? È la prima volta che si utilizza? Come il motore è controllato da un INVERTER ?
  4. #74
    cimi's Avatar
    Forse è questo provo a invertire i figli
    http://www.dhgate.com/product/a126a-...115709107.html
  5. #75
  6. #76
    cimi's Avatar
    Hanno lasciato i fili invertiti .. Man ho risolto il problema :)
  7. #77
    Eccellente, buon divertimento
  8. #78
    cimi's Avatar
    Grazie di tutto .... :)
  9. #79
    For everyone,
    Just for reference, this must have been a new machine and the problem was the spindle turned in the anticlockwise direction. It was a 2 wire DC spindle motor so the solution was to reverse the motor leads as described here, http://mambohead.com/wp-content/uplo...ion-Manual.pdf pages 20 and 26
  10. #80
    cimi's Avatar
    Yes I do not I changed because I was afraid of burning the spindle.... but now it seems that it's all right I changed the 2 wire DC spindle motor + and -with and working properly .... thank you very much EddyCurrent
  1. Chinese Spindles
    By Ricardoco in forum Generic Chinese Spindles
    Last Post: 05-12-2016, 12:16 AM
  2. BUILD LOG: From Chinese to Taffynese
    By Carlb1058 in forum DIY Mill Build Logs
    Last Post: 09-07-2013, 12:03 AM
  3. WANTED: 2.2 KW Chinese Spindle
    By Chaz in forum Items Wanted
    Last Post: 17-06-2013, 10:03 AM
  4. Chinese spindles
    By Colin Barron in forum Marketplace Discussion
    Last Post: 23-08-2011, 08:58 PM
  5. Chinese 1.5kw Spindles
    By jcb121 in forum Generic Chinese Spindles
    Last Post: 28-07-2011, 06:20 PM
