    vre's Avatar
    Lives in Athens, Greece. Last Activity: 03-08-2016 Has been a member for 2-3 years. Has a total post count of 33.
    I want to retrofit an old semi big lathe 1.6m distance between centers.
    So i got 2 servos 1.8kw 3000rpm 6Nm.
    I must choose between pulleys/timing belts or shaft coupler (ballscrew-motor)
    (I have already ordered X axis ballscrew+ballnut 1605 L700mm + single ballnut)
    Because i have not experience for this construction
    i want to ask what will be better for Z/X axis ballscrew diameter/pitch single or double nut and what will be better ballscrew-motor coupler or transmision with timming belts and pulleys.
    The lathe now has leadscrew diameter 30mm pitch 4TPI (~6.35mm) and has prismatic ways for Z axis and dovetail ways for X axis.
    Any suggestions that will help me iam looking for a good combination?
  1. Belts & pulleys,
    By jcb121 in forum Belt Drive, Pulleys & Timing
    Last Post: 28-09-2012, 11:32 PM
  2. pulleys and belts - sizes
    By mocha in forum Belt Drive, Pulleys & Timing
    Last Post: 22-07-2012, 04:16 PM
  3. Advice: Timing Pulleys and Belts
    By Mad Professor in forum Belt Drive, Pulleys & Timing
    Last Post: 24-06-2012, 11:30 AM
  4. Belts & pulleys & advice please
    By CNCBlug in forum Belt Drive, Pulleys & Timing
    Last Post: 29-04-2012, 09:31 PM
  5. Source for XL timing belts and pulleys
    Last Post: 20-08-2009, 12:21 PM
