    Good evening all,
    I have been interested in learning about CNC but as a complete noob I really do not know where to start. To that end I will be reading most of the posts to try and get my head around all the information available so I can as reasonable questions, and I have no doubt a few obvious ones. I am not an engineer but I do have my own woodworking shed; ultimately I am not looking for a huge machine just something around 450mm x 300mm x 150mm ish.
    Asdic, welcome, with a handle like that and Plymouth you must be a seafarer or an ex one ?
    Regarding the size of machine, up to a limit the size does not add much more to the cost, for example the electronics are the same it's just the mechanical parts so if you would rather have a machine that's a bit bigger you should go for that instead.
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 21 Hours Ago Has been a member for 5-6 years. Has a total post count of 1,148. Received thanks 202 times, giving thanks to others 5 times.
    Hello and welcome. I live about 20miles east of Plymouth, and currently using a "quick build" router made of MDF. If you have a couple of hours to spare, I could list just a few of the deficiencies of MDF as a structural material! Currently designing the Mk2 which will also be around 1200x600 cutting area but this time of steel. I don't have the experience of a number of the contributors to this forum but I do have a background in electronics, computing and model engineering (and I can claim to have built both a working CNC router and a 3D printer) and happy to compare notes some time. You aren't a welder, by any chance? Bit of a skills gap that I need to fill for my next machine!
  1. NEW MEMBER: From the South West
    By Neale in forum New Member Introductions
    Last Post: 21-12-2013, 08:35 PM
  2. NEW MEMBER: Hi from West Midlands
    By wiatroda in forum New Member Introductions
    Last Post: 09-02-2011, 09:42 AM
  3. NEW MEMBER: Hi all from west midlands
    By phillip in forum New Member Introductions
    Last Post: 28-01-2011, 09:18 AM
  4. NEW MEMBER: Hello from West Midlands
    By range3rrr in forum New Member Introductions
    Last Post: 25-09-2010, 12:58 PM
  5. NEW MEMBER: Hello from South West France.
    By magna in forum New Member Introductions
    Last Post: 19-09-2010, 08:27 PM
