Page 2 of 2 FirstFirst 12
  1. If you have just placed an order, I think you have ordered the wrong product. The uim24004 is a normal stepper driver. You need look at the uim243 range. These have the pulse generator built in.
  2. Gary, does the uim243 have an inhibit/limit input? if not then wont do what OP needs as he wants a parking feature too.
    I'd use an Arduino with a stepper driver shield, its quick, cheap and easily adaptable.
    Phill05 - pm me if you want some help on this.
  3. Quote Originally Posted by irving2008 View Post
    This UIM243 is a very simply and easy to use product.
    It is a stepper driver that has a pulse generator built in and can either have an external 0-5V speed reference or use an inbuilt in pot for the speed.
    It has an enable and run input.
    you can use the run or the enable in conjunction with limits, but a park feature would need a bit more logic behind it.
    You'd need four switches.
    2 DPCO to control the current direction in 2 coils
    2 SP to decide which coil(s) gets energised.
    As soon as you add a stepper controller you need to debounce the switches.
  1. Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
    By Mad Professor in forum Spindles & Drive Motors
    Last Post: 01-10-2016, 09:21 AM
  2. 800w spindle - noise & controlling remotely
    By HankMcSpank in forum Generic Chinese Spindles
    Last Post: 17-10-2013, 05:26 PM
  3. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 12:23 AM
  4. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 12:52 AM
  5. PDA Controlling A Steeper Motor
    By ceaser in forum Stepper & Servo Motors
    Last Post: 23-05-2009, 02:03 PM
