Page 2 of 2 FirstFirst 12
    Could you clarify that a bit, are you saying your table is a sheet of metal that is connected to plasma ground or something else?
    I only use my plasma manually, but have at times just clamped the earth to whatever sheet I've just cut the end of, then recut bits on top of that sheet. I've never had any issues with it not starting, but then mine has a high frequency/pilot arc start, so may be more tolerant of a less than ideal ground.
  2. The Following User Says Thank You to m_c For This Useful Post:
  3. #12
    The point was, do you connect it to the work or to the slat-bed?
    Or both?
    Generally the bed, as you don't any leads/clamps in the way of what you're cutting.
    Personally, I'd earth to the bed, and then use a jump lead from bed to metal if there were any grounding issues.
  4. The Following User Says Thank You to m_c For This Useful Post:
  1. Connection the plasma cutter to the CNC machine?
    By gr8fun in forum Plasma Table Machines
    Last Post: 22-05-2014, 10:49 AM
  2. FOR SALE: 3 sets of 4 xl pulleys and a plasma machine torch
    By nobby in forum Items For Sale
    Last Post: 20-05-2014, 07:33 PM
  3. Replies: 0
  4. Portable CNC flame plasma cutting machine
    By WandrinAndy in forum Machine Discussion
    Last Post: 03-09-2013, 04:09 AM
  5. CNC milling machine full support required
    By Rebekah_harper in forum Milling Machines, Builds & Conversions
    Last Post: 26-05-2012, 10:57 PM
