Thread: Giant 20' x 3' x 2' router build
the rails are pre drilled every 60 mm but have been told that i could probably bolt them less hence possibly going less. The hardest thing i will be machining will be ply wood but mainly 90% of the work will be foam. The rail is going directly on the extrusion which is 80X80 ali and using the centring t blocks. More than happy to listen to any other suggestions, i am basically just going by what i have seen on similar machines that have been built with the same intended use.
many thanks charlie
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
How Not To Build A Router
By Clive S in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 17-11-2013, 10:09 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
