    Generally speaking the best speed for aluminum is 8000 rpm. Thats what my tests show. 25 ipm feedrate is good feedrate to start with. No coolant or soap water or sprayed alcohol via airbrush.
    That's far too general and you can't say "Best Speed" because there is no "one" best speed for cutting aluminium there are far to many factors come into play which determine the speed.!! . . . . Material grade, cutter size, No flutes, DOC, Cut type ie: slot or side cutting, step over, coolant type . . . .And thats before you get into Spindle power and machine strength.
    Can tell thou 100% There is no ONE speed does all and you'll fluctuate between 7-15K when cutting ALi with 4-10mm tooling with varying no of flutes and DOC & S/F etc.
    Experiment is the best way to learn speeds & feeds and dont be affraid to cut deep, just be prepared and accept that you will break tools while finding the best cutting conditions for your machine and material.
  1. aluminium machining
    By drumsticksplinter in forum Gantry/Router Machines & Building
    Last Post: 15-03-2013, 12:19 AM
  2. RFQ: Aluminium frame Machining
    By mZeles in forum Projects, Jobs & Requests
    Last Post: 27-12-2012, 08:17 PM
  3. Machining Aluminium
    By Steff in forum Metalwork Discussion
    Last Post: 14-11-2012, 12:48 PM
  4. Breaking cutters machining aluminium
    By ukpete in forum Tool & Tooling Technology
    Last Post: 16-08-2011, 07:23 AM
  5. Aluminium Kress Spindle Holder
    By Lee Roberts in forum Metalwork Project Showcase
    Last Post: 16-07-2009, 12:00 AM
