    dudz's Avatar
    Lives in Bretagne, France. Last Activity: 20-05-2017 Has been a member for 4-5 years. Has a total post count of 256. Received thanks 1 times, giving thanks to others 50 times.
    I'm sure this must of been asked before but I can't find it.
    1/ To mill a pocket and leave the top outside edges without burs which direction should the spindle be traveling if the tool rotation is clockwise ? And when cutting an outside profile ??
    2/ What is the quickest way in cambam to send the spindle around the top outside edge of a profile to do a quick clean up ?
    3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle......"USB Breakout Board Interface 200KHz"....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
    I'd say cutter motion should be clockwise for the inside pocket and anticlockwise for outside profile, so the cutting edge is advancing to the oncoming work edge, as opposed to the cutting edge taking the trailing work piece by surprise. But I don't know from experience, so take it with a pinch of salt.
    Quote Originally Posted by CharlesJenkinson View Post
    That's Conventional Milling, using Climb Milling can give you very neat edges but only if your machine is rigid enough and has very little backlash.
    Either should give you neat edges if you have your feeds & speeds correct for the material & cutter, try a calculator like HSM Advisor [ Advanced CNC Speed And Feed Calculator - HSMAdvisor ] to check your current settings, the free 30 day trial should give you plenty of time to experiment,
    - Nick
  1. RFQ: CLOSED - Aluminium milling and anodising
    By AlexTsekenis in forum Projects, Jobs & Requests
    Last Post: 12-05-2014, 09:11 PM
  2. Milling Sheet Aluminium
    By p1lts in forum Metalwork Discussion
    Last Post: 07-03-2014, 11:23 PM
  3. Best Tips for Cutting 6082 Aluminium (CNC Lathe)
    By fidia in forum Metal Finishing Techniques
    Last Post: 29-12-2013, 06:09 PM
  4. 6082 Aluminium billet test
    By dudz in forum Metal Finishing Techniques
    Last Post: 22-09-2013, 09:45 AM
  5. Axis Directions
    By ptjw7uk in forum Linear & Rotary Motion
    Last Post: 08-09-2009, 05:37 PM
