Page 3 of 3 FirstFirst 123
  1. #21
    Hi compositepro,
    I still have not got around to getting coolant as I am still trying to learn how to use my CNC! I will look into the coolant you suggest.
    Many thanks
    Suesi
  2. #22
    Hi corkcnc
    Thank you for the info and your thoughts. I will have a look at what coolant I can get. It is good to know what your using and how your using it.
    Many thanks for your time.
    Suesi
  3. #23
    Hi all
    For anything Model Engineering..go for a semi synthetic
    Assuming Suesi has a sump and equipment to handle a soluble....go semi , I would suggest that normally, Model Engineers use their equipment in more of a hobby time rather than a business time. I raise this point, for coolants do not "stand" very well..I'll come to that in a mo..
    The disadvantages of milky "suds" or coolants are that they are predominantly oil based 80%. When mixed, they turn milky in the same way that Cows milk does and it is the refraction of light that gives this "colour". It has now become and emulsion but an Oil in Water emulsion.
    At this stage I will mention that WHEN you mix these products ALWAYS add the oil to the water. This allows the oil molecule to "coat" the water molecule...do it vice versa and instead of the coolant protecting the machine and workpiece the coolant is now an invert emulsion and will likely rust the machine and anything near it! Water coats the Oil. I should say..that I have never observed this but was advised by the boffins :-)
    Now when the coolant is "standing"...like any water that stands it becomes a breeding ground for bacteria ....the rest you will know.
    There was a mention of slideway oil. Anyone using either a slideway oil or other and is using coolant...the oil will find it's way into the coolant and in use the coolant emulsifier will emulsify a percentage of the oil. There will come a point, if not changed, the oil will float and the bugs will have a field day...then it will stink. I use that word because it's orrible. IF it ever goes this far...you really must sterilise the whole system but use a proprietary system cleaner...not bleach!! Water, bleach and metal just do not mix!!
    Therefore...a semi synthetic, having a LOW oil (20%) makes life very difficult for bacteria to get a foothold whilst giving enough oil for machine protection. Other "additives" within give better machineability. It will stand for much longer periods.
    When you have coolant in the sump...any coolant.. just circulate in the machine every now and again...say every few days or so...this will enhance the life of the coolant.
    It is very unlikely, unless anyone is doing copious amounts of grinding (again use the semi) to use a fully synthetic.
    There is nothing wrong with milky coolants as long as you know their limitations AND there is no reason why any of these products can be applied either by the proverbial washing up liquid bottle or the nippers water pistol!
    Always ensure that the workpiece material has compatability with the lubricant/coolant
    Always observe health and safety with any of these products, use a "water" barrier cream...don't be bashful and keep you hands out of washing up liquid..Use rubber gloves for the latter...that's NOT an excuse for NOT washing up!
    I hope that this little guide will be of some use
    Richard
  4. The Following 3 Users Say Thank You to Hallettoil For This Useful Post:
  5. #24
    Hello Richard,
    Many thanks for the help and info here. My machine is down at the minute as the power to my workshop kept on tripping with just the angle grinder or the normal power tools, waiting for the sparke! One I have the mill back in the land of the living and some time to use it I will place an order for coolant. I will be sure to read what you have mentioned several times over as I learnt a lot.
    Many thanks
    Suesi
  1. Canola oil as a coolant ?
    By cropwell in forum Swarf & Chip Management
    Last Post: 17-10-2015, 02:31 PM
  2. My Coolant System
    By Tenson in forum Swarf & Chip Management
    Last Post: 08-04-2013, 12:59 PM
  3. coolant
    By luke11cnc in forum Machine Discussion
    Last Post: 11-02-2012, 12:17 PM
  4. What coolant to use??
    By don_jarr in forum General Discussion
    Last Post: 05-11-2011, 02:12 PM
  5. eBay: Castrol Cooledge Cutting Coolant Suds
    By Lee Roberts in forum Items On eBay UK
    Last Post: 09-08-2009, 08:42 PM
