    I've had a search about but nothing much to find, here's the problem;
    Hiwin HG15 bearings come with a poxy little domed grease nipple, they have a M4 x 0.7 thread, I have a grease gun and grease but what fitting do I need to get grease into them ?
    Not sure what fitting they're meant to take, but in the recent build I just made my own adapters to fit in the thread (M6x1 in my case) and routed tubes to each bearing (and ballnut) so oil can be injected into them. Arguably a bit OTT... it depends how far you want to take it and how easy access would be to the existing fittings.
Name:	DSC01681 (Large).JPG
    I've decided to use grease but that's what I'm thinking, make some adapters. Quite a lot of the large motors I've worked on had extension tubes for the grease nipples because they would have been inaccessible otherwise. It's a daft design on their part I think, if only they were 6mm instead of 4mm. I'm thinking about a right angle adapter made of brass with a 4mm male thread and a 6mm female to take a standard nipple.
    But I didn't want to say that, I want to know what other people do with regard to greasing these and how ?
    used 4mm nylon elbows which were a push fit into the carriage
ID:	11791   Click image for larger version.
  6. The Following 2 Users Say Thank You to johnsattuk For This Useful Post:
  7. #6
    Looks tidy and good access to nipples, got a source for these elbows ? I can only seem to find pipe thread fittings.
  8. #7
  9. The Following User Says Thank You to johnsattuk For This Useful Post:
  10. #8
    Try these blokes they are excellent for things like this. I can't see any on sight but I bet they will have or will get you some.
    http://airaccessories.fluidfittingsshop.com/
  11. #9
    Thanks for the info on the grease nipples guys.
    Does anyone know what is the best type of grease to use in these linear rails ?
  12. #10
    Quote Originally Posted by davethefixer View Post
    This is the one I use, it's the right stuff at the right price.
    http://www.toolstation.com/shop/Auto...0/sd180/p89691
    Also read this thread
    http://www.mycncuk.com/threads/4862-...3206#post33206
  13. The Following User Says Thank You to EddyCurrent For This Useful Post:
  1. HIWIN from China
    By Gytis in forum Marketplace Discussion
    Last Post: 29-07-2013, 08:45 AM
  2. Hiwin HGH vs. EGH
    By dsc in forum Rails, Guideways & Bearings
    Last Post: 24-03-2013, 07:41 PM
  3. FOR SALE: Hiwin 25x5 C7 ballscrew + RSB nut
    By m_c in forum Items For Sale
    Last Post: 20-10-2012, 04:48 PM
  4. More reasonable prices on HiWin...
    By ecat in forum Gantry/Router Machines & Building
    Last Post: 15-03-2012, 02:57 PM
