Thread: 3d carving oak
Page 2 of 2 FirstFirst 12
    Quote Originally Posted by Mikeb View Post
    The width of the material has to be 400mm and total depth of it is 35mm with the relief going to a total depth of 25 mm
    theres 400mm x 50mm here but needs drying out lots of info out there on drying,he may have a dried out off cut Solid French Oak Board Floating Shelf Mantle Fire Place Beam Door Stairs WIDE | eBay
    Hi Mike, using a good quality waterproof glue and make up a panel the size you need by edge gluing and clamping with smaller matched bits of timber. I would use over sized kiln dried European or American Oak. Do a surface level on both the back and front surfaces to make sure the panel is nice and flat before doing the final job.
    Select some nice matching gain and you'll just edge gluing. You might want to increase the depth above the final finished from 10mm to around 15mm plus, DO NOT use biscuits or dowels as these might show up in the relief carving. As long as the finished job is well sealed it should last for many years. Search on YouTube as there's lots of helpful videos on gluing up panels. 4 Tips for Gluing Clamping a Tabletop - YouTube just miss out the biscuits. Mike :)
  1. Grey scale / height map / relief carving
    By totts in forum Computer Software
    Last Post: 11-08-2014, 09:47 PM
  2. V bit carving
    By Mikeb in forum Tool & Tooling Technology
    Last Post: 20-02-2014, 03:52 PM
  3. tools for 3d wood carving
    By chris in forum Marketplace Discussion
    Last Post: 18-01-2014, 03:23 AM
  4. 3d carving bits
    By drut in forum Tool & Tooling Technology
    Last Post: 04-07-2013, 12:03 AM
  5. Microcarve picture carving software
    By cnctoybox in forum CAD & CAM Software
    Last Post: 26-03-2012, 06:00 PM
